Topic: backstay diagonal: Above driver or above passenger?
On a cage where the main hoop diagonal terminates at the top hoop corner nearest the drivers head (and so does the dog leg and the roof bar-- so 3 tubes come together at the same hoop corner), where is the best place to put a single backstay diagonal in a chassis that's known to be flexible? In that same corner or on the passenger side? I know I could simply X the back stays-- but if I were to only put in one, which side would be the wisest?
A) Top passenger side- bottom driver side
B) Top Driver side bottom -passenger side
