Topic: Planning for and minimizing maintenance
So, total newb to enduros. So far my longest track time has been 30 minutes and thats only because i run out of fuel in my evo.  I've designed the thing to be stupid easy to maintain, taking the path of least resistance in ALL possible scenarios.  My endurance track pads last 12+ weekends, going on 20+ weekends on the OEM 2pc rotors.... blah blah blah.
So i'm planning a build and i'm seeing people talk about all kinds of maintenance items for their non-performance cars turned enduro racers. Basically, i'm trying to understand what i'm getting into and how to best maximize  maintenance intervals.
SO, starting out with a crx....
Wheel bearings : I can use stock crx hubs, i can use DA integra hubs/spindles. How long does a crx wheel bearing last? If i repack with synthetic race grease, how much time does that buy?   If i choose to use the slightly larger DA hubs/bearings, how long will those last??
Brakes: what are people noticing with brake life?  Stock size SI rotors last how long?  what if i source some DA rotors/calipers, what does that buy me? What pads do people like to use that has plenty of life and heat tolerance? I REALLY want to stick to the OEM rear drums on the car..... How well do drums hold up on hondas??
Axles: Assuming i stick with a D16, how do axles do on these cars?
Wheels: people often say wheels are a maintenance item for track cars.  I'd love to be able to race on some 14 inch steelies.  Or is it highly recommended i use something aftermarket?
Bushings: Which bushings are a must to upgrade/replace? I'm addicted to sphericals on the evo but i'm not sure how bad the penalties are for using sphericals in Lemons...
Suspension: I've seen great tricks on refilling OEM type shocks with 30wt oil.  Cool.... but i'd imagine that greatly increases the pressure seen inside the system.  How often does this type of mod blow shocks?
Am i forgetting anything? I did a bunch of research so i believe i have the oiling/cooling situation figured out.....
Re: Planning for and minimizing maintenance
lots of these fall in the category of "you should probably try and find out".
lots also depend how hard you and your team will be driving the car, and how good/poor of mechanics you are.
with the d16, once you get the head gasket magic down, you should have it relatively easy until you start driving faster. we never had a problem with axles.
unless you're totally set on building your own car... you should check out the sweet CRX that adam jabaay is selling the in cars for sale section.
our 97 civic (also for sale in the FS section...) was relatively stock bottom shelf autozone everything. the only thing we invested in was brake stuff, and for a while we had some nice wheels- but those kept getting stolen.
"THE WONDERMENT CONSORTIUM"
I definitely wouldn't swap out the rear drums, that's for damn sure.
Well the whole point of asking is to not replicate other people's mistakes smile
I guess i'm more interested in the drum, wheel bearing, and axle longevity above all else.
Don't know spit about Hondas other than some of them go through up to 3 head gaskets a day in Lemons.
Number one DNF cause is cooling.  Make it run cool and with the fewest number of needed hoses/connections.  Water and oil.
Spherical bearings in Lemons will get your grief from the judges.  Also, not needed.  You won't be driving 10/10th's and if you do, you'll likely black flag yourself onto the sidelines quickly.  Plus they are hard on all the bits around them.  There's some give in suspension components for durability and sphericals take that out.
Everything you learned about lines, driving fast, etc goes out the window in Lemons.  It's more driving fast while pretending you are the pretty cheerleader running the gauntlet of drunk football players.  Your goal is to get through there without getting effed.  It's not that Lemons is full of bad drivers, it's just the sheer number of them out there all with the same goals as you but at different speeds is what you have to deal with.  Sometimes you just have to slow for a second to make sure you don't put yourself or someone else in a irreversible situation.
I've had mixed success with shock oil.  Procurement is difficult because fork/non-foaming oil in the weights you want is difficult to come by.  Or at least in the quantity you need.  You'll find tons of it in the 1 or 2 oz size as that's what the off road RC guys use.  I ended up finding it at a specialty oil site but I don't remember which one.  Motorcycle fork oil doesn't come that heavy because heavy oil would make it like riding a jackhammer.  I used a graduated cylinder to make sure the same amount that came out went back in.  One set I quickly blew out but they were very old.  Another set were sealed so I had to drill a hole to get the old oil out and syringe the new oil in.  I had a hell of a time welding up the hole, I'm guessing because of the oil in the vicinity.  My welding skills are rudimentary so that's not really a knock on the process.  When I've gotten through all that, I've been happy with the results.  I suppose with a strut you can unscrew it and avoid all that but you still need to do something in the rear (especially on a FWD car) or you will have a miserable car.
Personally, I'd leave all the hi-po stuff for after you've done a couple races.  In the beginning your pit stops will look like Chinese fire drills and suck up seconds/minutes.  So all the time/energy/money you spend to gain 2/10ths a lap is pitched out the window when you can spend time sorting out your stops for zero money.
We are some 20+ races and 18k race miles on our EF Hondas, so I have direct experience with your questions
Bearings/Hubs: The EF stock hubs are too small, and we even sheared one off in normal racing, no impacts, in the 3rd race.  At that point we switched to DA knuckles/hubs/brakes just to get the larger and stronger hubs.  We get about 5 races out of good Timken bearings. We have worn the hardness off of one hub, and new ones are NLA.  Brake pads is all dependent on the pad you get.  After working through a few different carbotechs and getting 3 races out of pads but only a race out of a set of rotors (wear plus crazy uneven transfer layer, no matter how we bedded them), we switched to Raybestos ST43s.  They are amazing, we got 5.5 races out of the last set of fronts, and at that time the rotors showed NO wear, and never any fade, even using standard DOT4 fluid and no ducting.  The rears for the last 2.5 years are DA discs (because I hate drums) running porter field R4E, and they still have about 25% left on the same set of pads.
Axles: not an issue.  We only ever replaced them because we tore a boot and replacing it with another was easier.
Wheels: We have cracked 3 of a set of 4 wheels.  After that we bought a better set of wheels (Kosei K1 TS) and they have been fine.  We check them regularly for cracks.  Stock 14s are fine but I'd probably go with alloys (DA or EF) as I think they are wider, and Falken and Dunlop make tires for them.  Cheap too.
Bushings: Whatever are trashed.  The rear trailing arm bushings are most likely completely shot at this point, we have replaced ours, and rechecked them for lowering.  The fronts were already replaced on the first car when we bought it and we haven't touched them since, but they look fine still.
Shocks: Look for something used that doesn't completely suck, or just put on stock replacements.  Or try your idea, I don't know, we have used performance shocks that came on the first car and as rusty as they are, they still work fine.
Oil/cooling: This is where most Honda teams fail.  The ones that don't know that you need a big ass oil cooler and radiator, and to run serious oil. We have 18k race miles on our D16y8 like this.  A DA automatic w/AC radiator is twice as thick as the EF part and bolts in.  We also have a remote mount oil filter with a huge filter, on the way to the big ass oil cooler.  We run Shell Rotella T6 5w40 diesel truck oil, and it has been excellent.  We also have a ported oil pump, a weak point on these cars as they cavitate at high RPMs  (http://www.theoldone.com/articles/d_ser … ding_tips/)
One last bit of advice that will make the difference: keep your RPMs conservative.  We shift between 6200 and 6500, stock redline is 6800.
Our Honda is one of the most reliable cars I've seen around us, all these years and miles later and only twice has it ever really kept us off track for any significant length of time.
Chris from 3 Pedal Mafia
I can't say anything about Hondas either, but I can second this 100%. After about 3 races, we finally started paying attention to how the fast teams do pit stops and we quickly saved ourselves a lot of time off track. If you have time at your first couple races to just sit and watch the action, pick a spot near pit lane and keep an eye on the race leaders when they come in for fuel. Look at how their fuel jugs are set up, with big feed hoses and vent lines. Watch the choreography.
Also, major dittos to anybody who tells you to shift at conservative RPM levels or drive at 8/10ths instead of trying to go FLAT OUT all the time. What works for a 30 minute HPDE session might break the car after a few hours of endurance racing, or exhaust the driver to the point of making stupid mistakes, the consequences of which can be even worse in traffic.
I'm gonna give my two cents, even though I know little about Honda's
For our first race at NJMP this spring we ran Autozone Gold pads front and rear.  I would assume that it was Autozone rotors as well (I'm not sure because we bought the car from another team).   These pads ran fine for the whole weekend.
The point is that you should base your choices off of how hard you are going to drive the car.  As a class B car(93 Escort GT) that was turning moderately slow lap times we were not putting nearly as much heat into the brakes as a class A team.  That's why the Autozone pads were fine.
As a new team you are not going to be keeping up with class A, so there is no need to do every mod that you can for every once of reliability.  Run what you have and as you gain experience and learn the car you will know what you need to add to make it quicker and more reliable.
I would say that Sonic's advice is good because 3PM Honda's are wicked fast, but I do not think you need to do all of those modifications for your first race.
This is what I would do
DOT4 fluid - Motul RBF600
Follow Sonic's advice on oil and cooling
Bring an extra set of Autozone pads(if you are novices, if you have years if experience buy R4E or ST43's)
Go Racing and Have Fun
Moot Point Racing - 1991 Volvo 240 - #496
This was exactly what i was wanting to hear! Thank you!!  And its funny that you mention the ST43's because that's EXACTLY what i run on my evo 10! And i'm running 3640 lbs with driver, 310 HP, and 295 rubber!
So the DA spindles are a must then.... When you say races, you mean full 24 hour races? Or are we talking weekends of 25/30 min sessions?  As far as RPM limit, i had imagined that with all the oil/cooling mods you mention, revving to 7k shouldn't be a problem? I mean, D16's have a decent rod/stroke ratio so bearing wear shouldn't be too bad.... And you can always balance the crank just in case....  I understand why people shift early with less attention to oil and cooling and i totally agree with that.... i'm just curious if i should challenge that idea as long as the proper supporting mods are done.... including oil pan baffling. I'm also a total noob here so feel free to take me to school.
Also, what do you run for springs out of curiosity?
Hispanic Panic wrote:
As far as RPM limit, i had imagined that with all the oil/cooling mods you mention, revving to 7k shouldn't be a problem? ... i'm just curious if i should challenge that idea as long as the proper supporting mods are done....
I'm sorry, how many spare engines did you say you were planning on bringing?
11 (edited by OnkelUdo 2016-09-22 07:56 AM)
This!
The teams that make these "bulletproof" on the street and in HDPE's engine last more than 9 hours per head gasket in Lemons are NOT the norm.  They are the ones that figured out the secret sauce but feel free to experiment.  Of 5-7 various Honda 4-cylinder motors at an average Midwest 14 hour race (the norm, true 24 hour races are rare) we probably see 4-6 head gasket replacements.
Keep in mind, the two most reliable engines I know of in 24 years of wrenching, Toyota 20/22R/RE and the Dodge Slant-6 have had huge endurance reliability flaws exposed on the Lemons track. Everything we think we know about reliability gets challenged by the crucible of budget racing for 8-24 hours a stint.
When I said races, I meant entire Lemons races including the testing day we almost always do, so each one is 700-1000 miles at race pace. I'm not counting the handful of HPDE days the car has been in, as in comparison those seem like almost nothing.
Rev over stock redline at your own risk. I've seen plenty of Honda teams do that and all of them have not had nearly the engine longevity of those who are a bit more conservative.  If your goal really is to minimize working on the car like you say, this is the easiest and most effective way to do that.
Spring rate: I'm not totally sure as the springs are pretty rusty and all were used cast offs, but I think we are running somewhere around 300f, 350r.
The above is very good information...IF...you listen.  Your suspension won't matter when you're in the pits with a blown HG from overheating, or doing an engine swap because of overrevving.  We also run a big oil cooler and big filter, along with Rotella T6 5W40 oil, which is changed every race.  Our redline on our B20 is 7,000, but we shift at 6,500.  No need to rev it to the limit in a 14 hour race.  A shift light really helps with that BTW.
I love all the Honda blown head gasket posts.  We ran our old Prelude for 10 races (2 were actual 24s) and it never exceeded 200 degrees.  When it finally bit the dust, we broke a connecting rod, but the OE head gasket was just fine.  Don't let it overheat, and use only a OE MLS gasket and you'll be fine.
To keep all the temps in check, get a set of real gauges to keep an eye on the water temp, oil temp, and oil pressure.  I'm not sure on the D16, but on a B20 if you have less than 70PSI of oil pressure at WOT, it's likely headed south.  Our has 78PSI even with oil temps as high as 292F...that was before we added the oil cooler BTW.
Listen to Sonic. And to everyone echoing the rev limit thing.
Endurance racing stresses a car in huge ways. You are WOT for hours at a time. If you want an engine to last, back off the rev limit. Some cars just pulling it back 500rpm is enough. Some people mandate 1000rpm. This is not HPDE 30 minute sessions. This is not time attack. This is endurance racing, and you need to change your mind set to survive.
It's really not hard to keep an engine alive. You need to keep it cool, you need to keep the oil in it and at pressure, and you need to not rev the life out of it.
Abandoned E36 Build
Just curious- do you have VTEC enabled or disabled?
16 (edited by Sonic 2016-09-22 05:39 PM)
VTEC is enabled and works fine.  This motor is a champ.  We have no idea how many miles it had on it before we put it into race duty, as it was in my mother's winter daily driver for 10 years before it was in the Lemons car, and before that it was pulled out of a junkyard in about 2001. It now has low compression on one cylinder by 25%, and another down by 10%, but it just keeps running, and even down on power it was enough to win B and come in 9th at the NJ race this year.
Sonic has all the tricks worked out.  I'll throw in my "me too" statements only because we ran a 91 CRX Si for 4 years.  I finally gave up on it when the rear toe adjusters rusted out for the 2nd time.
I chip all our Honda ECUs.  Not for performance, but to bring the rev limiter down.  When we were running D series motors, I'd pull the redline cutoff down to 6400 rpm.  With the B series we run today (EG Hatch and DelSol), I've got the redline set at 6200 rpm.  I don't trust my drivers to shift when I tell them to.
I'll echo Sonic's cooling advice.  Big radiator, big oil cooler, port the pump if you can.  Get real gauges and use them.  The Honda motors sit on the verge of overheating in stock form.  That is part of how Honda passes emissions tests.  You have to dial in a huge amount of additional cooling, or you will overheat, float the head or toss a rod.  The added cooling and oil volume is NOT a reason to abuse the motor more.  It is just getting you back to status quo under race conditions.
We ran stock Si knuckles and bearing for years before I switched to DA stuff.  Bearings are a maintenance item for us.  I replaced every 3 races no matter how they seem to be working.
Never had a problem with axles.
Even on the smaller Si brake setup, we used stock/cheap rotors and Hawk Blue 9012 pads.  Normally I'd have to replace pads at the same time as wheel bearings - every three races.  We did a rear disk conversion on our CRX using parts from a Civic EX.  The rear drums are usless in a race after a couple laps from drum expansion.  I never could replace the proportioning valve, so I suspect the rear disks wern't doing much more either.
Suspension is a harder nut to crack since you have budget concerns with Lemons.  We ran for a couple years on cut springs and stock shocks.  I eventually got enough residual for some bilstiens and proper springs.  I don't recall the spring rates, but the real cornering work on our suspension was done on the bump stops.  Invested in some nice bump stops and did the math to make sure they were helping rather than hurting.
I've never had a problem with wheels that wasn't self induced.  Turns out, if you don't hit stuff, your wheels never get damaged.  We run Rota Slipstream knock offs (Speedy Race Mode).  Light and cheap.
I'm a WINNER!
Thanks for all the input guys!
As far as honda head gaskets, which ones do you guys use?  There are i think 3-4 different specs for D series gaskets depending on the model.  I know Y8 gaskets tend to be thinner vs others. I was just curious if anyone has noticed anything among the gaskets?
We always use the stock multilayer metal gaskets for which ever block/head combo we have.  The notorious Honda head gasket problem isn't due to the head gasket, it is due to heat stress.  We stopped popping head gaskets when we cooled the engines properly.
I know the internet is full of thinner gasket options for pretty much every D series engine combination.  Thinner gaskets are supposed to give higher compression.  They might, but higher compression without compensating engine management is asking for trouble in an endurance race.  Yeah, the compression gains should be really small, so it shouldn't hurt anything, but if the gains are so small, why use something other than stock?
I'm a WINNER!
Interesting, I had always assumed it was the open deck design combined with high RPM.  The cylinders fretting against the gasket.  Seems like almost every successful open deck racing engine I can recall runs Wills rings or similar instead of a standard type gasket to help alleviate head gasket failures.
Hmmm.  Saying the head gasket problem is only due to heat stress is a bit of an oversimplification, I'll grant you that.  More likely the problem is a combination of factors:  heat stress, open deck and over square engine.  Fixing one of those tends to make the failure less likely.  Cooling is relatively cheap and the connecting rods appreciate it as well.
Back when we were losing two head gaskets a race, the RPMs really didn't matter.  I could over rev the stock limiter by 1000 RPM, or drop the limit to 1000 below stock with no real change in the failure rate.  After adding a large radiator and oil cooler the head gaskets will outlast the piston rings...
I'm a WINNER!
Hispanic Panic, did you say where you were from?
I asked somewhat of a similar set of questions a few months ago. Sonic and a few others were kind enough to send me a list of musts for our honda (92' civic cx). If you are local to the New England region we will be at the NHMS event running 95% of what he has suggested to do. You are welcome to swing by and check on our progress or lack there of.
All of the thing he has suggested with the exception of brake pads, can be done for very cheap or free.
Oversquare?? I was under the impression that the R/S ratio was relatively favorable in the D series engines.
What's to stop someone from pressing rings into the block to change it to a semi closed deck design?? Engine building isn't my strong suit, so correct me if i'm wrong.
Fyi, though y8 gaskets are almost half the thickness of other d16 gaskets, they're usually 10-15 dollars cheaper.  So, THATS why you should consider it :)
It seems overall there are two goals with the D series, expelling the heat and maintaining proper lubrication. It is easy to see that the rev limit imposes little  bearing on the heat issue. So assuming you're expelling heat fast enough, all that's left is making sure your bearings stay lubricated, which means making sure your pickup always has oil and making sure the oil temp stays within a proper range. I think the point i made earlier is that if you're doing everything you can for the oil, i don't see why you couldn't increase the rev limit. Of course you wouldn't know this until you're able to monitor both temp and pressure with a good enough resolution. I know there are plenty of data points that would say the opposite, but what isn't clear is how many of those datapoints properly addressed the problems.
BTW, i' live in texas, so no east coast trips  for me yet :(
The rod stroke ratio of the D series is pretty awful, 1.52:1. Stroke of 90mm, bore of 75mm.  The inertial forces that come with higher RPM are brutal, leading to the oil not being able to maintain the lubrication and the additional bit of flexing from the huge forces.  It sounds like you are bent on trying high RPM despite the overwhelming first hand evidence that it is a bad idea even with good durability mods, so go for it and tell us how it works if you find some
Magic Bullet that we haven't yet.  If your goal is really to minimize maintenance like your thread title says, just follow al of the recommendations above from those who have done this for years.  At first none of it will matter at all for you in the standings as it will take you a few races at best to have a good idea of what you are doing to the point where a few seconds/lap will matter. Until you have exhausted gains in those other areas take the easy and traveled route to keeping the engine together.  Once you are running tight races then start to experiment with higher revs to your hearts content.  Bring spare motors. Eventually you won't be able to do anything else to the oil to rev more, especially in a budget series.
You can get a block guard to close up the deck, though that can lead to other problems
Due to inconsistent expansion rates, reduced coolant flow and hot spots.
Did I say oversquare?  I meant undersquare.  I always confuse those.  Most of the Honda 4 cylinder engines are on the wrong side of square...
I'm a WINNER!
