Topic: Tying OEM dash bar into the roll cage
I'm caging another Sentra, and there's an OEM 2" metal tube running from corner to corner, right about where a dash bar would normally be. It serves two functions: stiffening the car and holding the steering column.
Given how dash bar is optional, do I:
- Notch the OEM tube for front stays, install it in factory position, and weld it to the cage at the notches, or
- Notch the OEM tube but not weld it to the cage, or
- Install a new 1.75" dash bar and weld bits of OEM tube to mount the steering column onto the new dash bar, and weld stubs of OEM bar to tie it into the base of the a-pillar, or
- Install a new dash bar like above but skip stiffening altogether. (this is how I built the last one) or
- Mount the steering column to the firewall and skip all this dash bar business.
Anybody done one of those? I'd strongly prefer #1 but to this day I still don't have a firm written ruling on roll cage tie-ins and non-essential components of the cage being replaced with different diameter/thickness tubing.
