Topic: Removable panel to access distributor from cabin?
OK, so I actually did a search and found a thread talking about this topic, but didn't see an answer or solution.
Our new engine is pushed back against the firewall, to the point where access to the distributor comes in two flavors:
1) Pull the engine
2) Access from inside the car
With the sealed firewall rule (a good rule), is it possible to make a removable panel for access and still be safe? Van's have a dog house, and that's the concept we are thinking about.
With proper sheet metal gauge, and a gasket as a seal, using bolts w/ weld nuts, or other removable fastening methods what's the thoughts?
There's no question we want to be safe, and if it's not safe it's not being done. But we also are looking for guidance and insight before we proceed with a plan. I know the rules have a link to Phil for residual value, but I've missed the link to submit tech inspection questions somewhere so I'm starting here.
Thanks as always.
2014: Gingerman x 2 | 2015: Gingerman, Autobahn (24 Hours!) | 2016 Gingerman (April) | 2017 Gingerman (April)
