Topic: New Team in NJ - advice
3 other friends and I just picked up our car. It's an 86' AW11 with a bit of rust and soon to have a lot of elbow grease. Our plan is to start with the NJMP race this season and then hopefully roll into the other 2 northeast races this summer. We have all our receipts and saved the craigslist ad to help in defending the price of our car. We've also gone through the rules a number of times and feel fairly comfortable knowing what we need to change/add so that our car will pass tech (most nervous about the roll cage). Additionally each of us is slowly acquiring SFI rated racing gear to be legal. After all that work, we'd hat to not be able to race. I've seen that there are a few races where teams get waitlisted/rejected due to too many applicants for a race. Is this an issue at the NJ race?
I've seen that teams with good themes get priority. Our number one mission is to get the car ready for a safe, fun weekend of racing. That in mind, how much time should we put into a theme?
Re: New Team in NJ - advice
We are doing our first race at Barber's this weekend. We spent about 9 months building our car (mazda MX-3) and only about the last two weeks with one guy working on the theme. Our priorities were the same - car first, then theme if we get to it. We got to it, but most of it will be removed before the car goes on the track. There are lots of teams from races I've been to that don't bother with a theme at all. I don't think you have to have the best theme in the world. But if you at least do something, I'd assume you'd make it in over a team who did nothing.
That said, we're in the Southeast region. The races are well attended, but not overfilled like some areas.
OutlawAnything wrote:
..... (most nervous about the roll cage)......
What??
IF you have concerns or questions ask them BEFORE you build!!!  Waiting until you are at the race is asking for trouble.  Yes, the rules are very clear, but you can and will run into things that are not covered.
Bill
2017 NJMP #24 Team Super Grover, DNF, MF, WTF.........
And Please, ask BEFORE you weld and preferably before you cut, it makes it less awkward when someone has to tell you that won't work.
If you have signed up for jersey already you should be fine.
It does sell out occasionally, but earlier signups seem to get a little bit of preferred treatment with regards to getting waitlisted.
The theme will help out at BS inspection time, Impress the judges and they wont break your balls to hard.
Lame or no theme and you will likely get BS laps added on.
Reliability first, Theme second, go faster Third! ............Remember this!
Most teams will give you advice and help on the race weekend. Don't be shy, ask questions,its all in fun!
Look out for the old Rover with a Grover stuffed muppet on the roof. Stop by and say Hi.
Manny.
Post pics of your cage for us veterans to critique.  We may save you some trouble.
#411
'93 Acura Integra
Start with another car.  Seriously.  I owned/raced one.
1) the cage is going to be hell to make.  If you leave the roof on (and we didn't) then the cage is going to be very low and you will need to bolt the seat directly to the floor.  The rear stays should go through the rear window area to the strut towers.
2) It's a mid-engine car.  It will try to kill you every chance it gets.  Oh, you're going into turn 1 and a little off line - let me spin you around and show you that apex you should have hit.
3) the 4AGE engine is notorious for spinning bearings if it loses oil pressure for even a second.  A single nice long turn will do that by taking the oil up into the valve covers and away from the pick-up and starve the oil pump.  On top of that, the stock pump cavitates at high RPM so you real racing red line is much lower.
I could go on, but I would not consider it a beginners race car.
where in NJ are you?
These guys are veterans of the series and I would seriously consider their advice in regards to your car choice.
1990 RX7 "Mazdarita"
Outlawanything- not sure where you are located but we are in South Jersey and running 3 cars at NJMP this year.  You are welcomed to stop by and see what we have done.  All 3 cages built by different people and even another team a few houses down with a car that I believe RobL above built.  If you're not local it would be a good idea to befriend a team near you to bounce ideas off of.  Dirt cages are often not legal in Lemons.  Also, don't worry about being accepted just put in your app now and you'll likely be fine.
Team Glue Sticks
00 Firebird, 02 X-Type, NX200, 00 Mazda 626 (Sold)
2016 NJMP Heroic Fix, 2017 NJMP Near Heroic Fix except we can't drive
In you're in the northern part of the state, you're welcome to stop by and see our car any time. We're based in Rockaway with a '90 240SX. We're pulling the car from storage next weekend and will most likely see some garage time every weekend between then and the race. We've learned a lot over six races and two years.
Chief Gadget Inspector
Seven-time Loser
1989-91 Nissan 240SX
Same offer here.  We're spread around the state, but the car sits in my driveway (well, lawn) in Butler, NJ.
What??
Bill
That is why for our 1st build we PAID to have ours done, even know we have a great welder/fab guy. We didn't want to have any issues, however after seeing some of the cage work....
http://i68.tinypic.com/1zx427t.jpg
Good to see another AW11 there. We will be there in one of the garages, not sure which one yet. Car 351, the cosmonaughts.
I have to mirror what other people said. Ask cages questions early and often. The cage in our car came with it but hand't been raced in 10 years and had to be modified for Lemons. it is tight an uncomfortable for a taller guy (6'2") like me. We picked up a new car at the end of last year, but that wont be ready for this race, we hope to make a better cage with more room and safety.
Also as previously mentioned, this car will try to kill you. It is not a good car to start with, and arguably not a good car for Lemons because it does not like lifting in the corners, and other associated evasive maneuvers in the corner that are common at Lemons races. We have finally gotten the suspension/brakes/tires to a point that the drivers on our team can recover safely when it tries to switch ends on you. Also, add a splitter/air dam to the front. These cars get super light in the front at the high speeds through the last corner of NJMP and the straight.
We ran our first race on the 4age, and then blew two of them at our second. Both were pretty tired engines and even with our added oil cooler and sumped pan and valve cover drain backs. These engines are also hard to find nowadays, so much so that we actually made money when we sold our blown engine and bought all the parts to do a 1mz swap. if you are set on keeping the 4age, I would set up a oil pan with extra capacity and trap doors, add an oil cooler, and an upgraded radiator.
Feel free to contact me if you have any questions about set up, or if you need any spare parts. We have a ton Mk1a parts since the engine swap and are now running Mk1b rear suspension.
The Cosmonaughts - 86/88 MR2 with 1MZ V6
Another new AW11 team here!
I guess I'm in for trouble as well. The car has a monster oil cooler in the right fender vent, any real benefit to it? Or is it mostly an oil pressure issue?
I saw your other post about your cage - oy, you guys are behind the curve on this...  The oil cooler is there to keep pressure and keep the oil from deteriorating.  Look at what I said about cavitation, and add heat and low pressure and you are in for problems.  I imagine that was a regular racing (SCCA Sprint races) car and not an endurance car and they need that cooler to keep the engine together.  Now imagine racing for 10-16x as long - 5-8 hours vs. 30 minutes.
--Rob
At present the car is in Staten Island with one team member. 2 of us live around Secaucus and the other is upstate NY. Not so nervous about the snap oversteer. In fact it's one of the reasons we kind of like the car (we really wish we found a turbo instead of the N/A, but our financial stooge couldn't cut it). Our seat arrangement is on the floor and we all fit just about perfectly with it that way and we maintain the 2" helmet distance. We found the diagrams of the 3 cage options. Our setup currently is the right/left main bar (fig. 1C of how not to fail Lemons tech), but our issue is that the header bar is not contiguous, nor is the main bar as it gets close to the main hoop (fig. 1C). Everything else is how it looks on the diagram (except we need to weld it to the floor). Our thought is to convert it to the Halo type (fig 1B), which would get rid of our non-contiguous sections and get the cage within spec. I've seen pre-cut pieces for sale on places like Summit, etc. and other speed shops for a reasonable price, and would just need to trim to our specs.
18 (edited by OutlawAnything 2017-04-01 02:29 AM)
My Teamate already posted this issues with pics in the tech area, but in case anyone didn't see it... attached are 2 pics, hopefully they convey what I tried to say above.
http://i667.photobucket.com/albums/vv35/bmvoigt/IMG_1386_zpsubducgij.jpg
http://i667.photobucket.com/albums/vv35/bmvoigt/IMG_1387_zpswabklppq.jpg
From what I have seen the bolt in cages as a whole are not acceptable. Even cutting out the "halo" section and replacing with a contiguous piece will be difficult and may still not make the cage legal.
Need more pics!
Nix that last post. Didn't see your separate cage post in tech section.
Is that whole cage a bolt in?  It is highly advised by everyone not to attempt to convert a bolt in cage into a welded one.  Tech will not like it.  It is also highly advised that you find a local team in North Jersey there to check out what they've done and maybe pay them in beer to advise you on how to build a proper Lemons cage if you're intent on doing it yourself.  Even if you can weld, having someone who has installed a cage, or several, before is a huge asset and will save you hundreds of dollars and countless hours of cutting out what didn't work right the first time.  There is nothing worse than getting to tech Friday before the race only to have the inspector fail your cage.  Especially when you're hours from your shop.  At a minimum a couple guys on this thread are extremely experienced cage builders and can guide you in the right direction.
Team Glue Sticks
--Rob
As an additional data point for the oil pressure discussion - if you can make the dollars work, a properly sized Accusump unit with the right hoses should take care of your transient pressure issues. One of the best known amateur MR2 endurance racers around (Bill Strong) has successfully used those units for the past ... decade? to keep his motors together in a car with aero and tire setups that far exceed anything a Lemons car is likely to have. Granted, he runs a MR2 MK2 with a V6 but those motors were also notorious for starving in sustained high speed turns.
I have my own MR2 AW11 (my ... 5th?) , and you might say they are my obsession. I raced MK2's the last 5 years with the Mod Squad team and (hopefully) learned a few things.
I'd be happy to talk to anybody that would like to do so - here or offline, and am also located in (central-ish) NJ
Mod Squad Veteran (1991 Toyota MR2)
Incredibly mediocre race driver
Lemons Enthusiast!
Well, looked like it all worked out in the end. Congrats! You guys are champs (also, the one team that didn't throw in the towel after failing tech for cage this saturday).
With regards to oil, drill/tap a hole in the head, driver side rear corner or center (see smallport 4age head drainage, that's the setup you're trying to replicate). Otherwise, you'll eventually run out of oil on fast right-hand sweepers.  [props to googly-eyed corolla for the tip].
K Car Stalker
Thanks everyone!
You guys are a really great racing community. We couldn't do it without all your help. The garage space. The battery wire. Sasha. The borrowed welder setup.
We set a goal to cross the checkered flag. After 3 rollcages in 1 week, a blown tire, an incident with a wall, and a little nudge from a Mustang, we crossed the line in dead last place. (Broken transponder!) We were proud to finish.
We plan to drive up to NH this year for the next one. Trailer might have a few beers. Stop by anytime!
Glad to have meet you guys and happy to share the garage with you guys. Look forward to seeing you at CT or NH. Also as far as oiling thoe 4A-GE, as mentioned looked at tapping the head or valve covers and putting some large diameter oil drains. we had a set of valve covers and matching oil pan that we used with the 4a. I think it had 1/2" id hose running from the ends of the valve covers to the oil pan.
~Chris
