Topic: Car Numbers will this pass. Hint it was not a sober job.
This weekend after a case or 12 we decided to apply the numbers to the car. In the pictures (if you can see them) we all took one side of the car and that's why the numbers are off. I know its a really bad job but we thought its perfect for the race. Could the numbers pass for inspection or do it sober for better results?
http://i66.tinypic.com/sfb381.jpg
http://i68.tinypic.com/wisfok.jpg
http://i65.tinypic.com/1zgddw6.jpg
Re: Car Numbers will this pass. Hint it was not a sober job.
Sober up and try again.....
Put yourself in the shoes of a corner worker trying to read the numbers on a particular crapcan in a pack.....
FREE COCO
ArseSweat '12Vodden '12ArseFreeze '12I.O.E.!! Pointless'13.ButtTurrible'13..Vodden'13Pointless '14Miller Lemonites'14..ButtTurrible'14.Vodden'14. ArseFreeze'14Good Effort '15  Pointless '15 PNW '15  Vodden '15..I.O.E!! Miller Lemonites '15 ArseFreeze '15 Vodden'16  B.F.E.'16 ArseSweat'16 Heroic Fix PNW '16 IOE!!ButtTurrible'16ArseFreeze'16
Unless those workers are working in the same condition as you were when you applied them?  Yes redo them.
You can get all artsy with the car but when it comes to numbers you want them easy to see and read. It sucks when you get black flagged and it turns out that it wasn't you but some other car with a similarly badly designed number and the corner worker misread it. Don't be that guy!
Use more "blocky" numbers.
Numbers are HARRRRD!
Butt Sweat & Beers.
