Topic: I need a chunk of a SBC
I am repairing the broken bell housing web on a Small Block Chevy. I only need the area with the 3rd  bolt up from the driver's side.  4" to either side of the bolt hole would serve my purpose. So if you have a scrap Small  Block that is going to get tossed & are willing to cut that section out & ship it I am willing to pay for it. I will also be at the upcoming Sear Pointless race if you just want to bring the block.
Tired Iron Racing, 29x loser with 9 top ten finishes.
2 (edited by DelinquentRacer 2017-03-01 12:09 AM)
Re: I need a chunk of a SBC
I've gotta scrap block in Petaluma.
Can you send me a pick, or post one, of how much you want?
I can probably get it to you this weekend.
TRUMPACO XR4Ti (We've arrived!! Now if I could make it go faster than 65 mph.)
The One & Only Taurus V8 SHO #31, w/Improved Smokiness (now in rehab)
2008 AMP Survivor, 2008 ARSE-FREEZE-APALOOZA Mega-Cheater
You need this:
http://www.alumaloy.com/castaloy-specs
racinrob wrote:
You need this:
Over the years I have tried a lot of odd promise everything miracle  alloys but for this project I think I will stick with good old high nickle "Farm Rod" or I will TIG braze it.
racinrob wrote:
You need this:
It may work if he had an aluminum LS motor but he says he has a SB Chevy which to me means a cast iron block 350 CID old school Chevy V8.
A braze, TIG, or even MIG weld with the correct filler rod or wire should fix it.
Do preheat the block and cool it slowly. One way is to bury the block in sand with the part to be fixed exposed. Heat up the block slowly with a "soft" flame torch and then do the fix. Then cover the whole block to slow cooling.
There are better ways but also more involved and harder to accomplish.
Cylinder head repairs are way easier as you can put the whole head in an oven to get it all to the same temp. before welding on it.
That's what I did to a head many years ago. I also MIG welded on it with the correct filler wire. It worked fine for me for years afterward.
jimbbski wrote:
racinrob wrote:
You need this:
Jim, the link is for castaloy, made for repairing cast.
