1 (edited by moparfan 2017-03-27 08:30 AM)
Topic: 92-00 Honda Civic cage - Charleston SC - NO LONGER AVAILABLE
Retiring a Honda Civic chassis that has a well built cage that has been racing in Lemons for about 4 years. It is 1.75 DOM tubing built from scratch (no kit). Driver door bars are Nascar style and fit inside the door. If you want it make me an offer. I will cut it out by removing the chassis from around it leaving the spreader plates on it. The easy button is to cut the top off your car, drop the cage in and then weld the top back on your car. You will have to cut the A and B columns at the bottom of the glass openings. It is currently in a hatchback but with very little modification it will fit any fifth or sixth generation Civic body.
