Topic: roll bar padding
we were just wandering since the cage has to be inspected at tech if the roll cage padding should be installed before or after tech.
Re: roll bar padding
Before.
They'll be checking the padding as part of tech.
As long as nothing else on the cage gives them reason to be suspicious they shouldn't be crawling over every single joint. Exception will be all the joints at the roof, they will feel around them to make sure they are fully welded. Should be possible to leave a very small gap for them to see those joints while still having the required padding in place.
ok, thanks for the quick response. also just curious we are going to be at cmp when do most early arrivals start getting there?
If you post on the CMP thread you may get a better response.
http://forums.24hoursoflemons.com/viewt … p?id=34554
Team Glue Sticks
00 Firebird, 02 X-Type, NX200, 00 Mazda 626 (Sold)
2016 NJMP Heroic Fix, 2017 NJMP Near Heroic Fix except we can't drive
