Topic: Free D16 pistons
I have some gently used pistons coming out of the engine I'm rebuilding. The block needs to be over bored, so I can't use the pistons. They all measure between 2.9520-2.9524". This is the "as new" spec. They've got carbon on them, but they're not damaged.
These are 2PE pistons. You'll just be getting the slugs, since I'm reusing the rods.
Located in NC
