Will there be room for the heads?
the bottom left head is installed, you can barely see it peeking below the muffler shroud. it is missing the valve cover still, but that's only about 1.3" tall
you can kinda see it's position in this closer picture:
or in this slightly blury picture:
when you're done with the mid engine setup, let me know how I can help you move it to this:
making a plastic model of the MR2 or moving the whole setup to a mini?
