pennintj wrote:TeamLemon-aid wrote:How many HP do you think you have? That car is AWESOME!
Looks like the donor was either a Moto Guzzi 1000SP or a Convert due to the floorboards, heel/toe shifter, rear disk brake and 28mm Del Orto carb non-pumper setup. Stock horsepower on them is roughly 60hp +/- according to specs. You could bump it with the big valve heads, carillo rods, agostini timing gears and some 40mm flatslides, but then you'd blow your $$$ limit for Lemons....
-=Tom
Correct - is/was a '75 Convert - spec is 70hp, but realistically, probably closer to 60 as stated. The stock 600 motor was rated at 35hp. However, the one that came with the car was hopelessly seized, so it would have made 0 hp.
Kept the Convert motor stock due to cost, and the 600 driveline is only good for about 80hp and it starts to explode. The stock 600 clutch was used, with stronger springs thrown in to the pressure plate.
Kind of the amazing thing is, to make this work, only 2 custom parts were needed - a spacer/adaptor bell to mate the 600 flywheel to the guzzi crank, and an adaptor plate to hang on the guzzi crankcase to give me a place to bolt the 600 transmission onto. Everything else is stock parts. Well, ok, the Dellortos would have smacked into the bellhousing, so had to make new straight inlets to hang the carbs on.
Chris
"Chief Idiot" - Italian Stallions Rotary X1/9
Class Win (Bad) / IOE Win (Guzzi Fiat 600) / We Got Screwed / GRM Most from Least
