Re: budget water injection for lemony boosted vehicles?
Marc wrote:
yeah, the carb may be over thinking it.
anywhere else this would have been followed by "you're retarded, you must have been dropped on your head as a child". i love this place smile
as for a pump, you can get 30psi cheap here: http://www.surpluscenter.com/item.asp?i … name=water
or 60psi for a bit more: http://www.surpluscenter.com/item.asp?i … name=water
max flow does not matter, i can't see needing more than .1 gal/min and realistically probably no more than .025 gal/min
and yes, i could whip together a PIC easily. i'd probably use something more complicated i already have hardware and code written for but the point remains the same.
heck, it would be fun to roll your own entire ECU for lemons, i bet the judges would let it fly to see it fail smile
I'm still wanting you to make me an auto trans controller so I can throw a 5 speed in the lex... will take me 10x longer than you to do it!
27 (edited by RobL 2012-05-10 06:03 PM)
tSoG wrote:
I've seen pre turbo methanol misters run on turbocharged pressure on diesels. not saying it's ideal, but it's lemony and takes "what's the worst that could happen?" to heart. smile
Yep - so have I:
http://img372.imageshack.us/img372/166/ … sor9eb.jpg
RobL wrote:
Yep - so have I:
is it possible something went wrong with the nozzle or it wasn't fine enough? i mean, otherwise carb/turbo drawthrough systems would all have the same problem.. right?
in your car, did you inject water before or after the air/air intercooler?
29 (edited by RobL 2012-05-10 08:45 PM)
That wasn't my car, It's a picture I have from someone who was injecting pre-turbo.  The difference between water injection and a drawthrough system is that the jet atomize fuel into a much finer mist than a water sprayer - it has to do with surface tension and evaporation rates.  Basically water wants to stay in liquid droplet form while gasoline wants to atomize and evaporate.
In my car, I tested both pre and post intercooler injection.
Here is what I found - for straight up lowest intake temperatures, pre-intercooler.  However - for best combustion results, it was post IC and as close to the butterfly as I could get.  In the end, I went with the post-IC injection.  It was easier to tune.
I'm going to bed - I'll elaborate more tomorrow.
Here's a thought, and it would take some logic to implement and tune correctly, but why not spray E85?  It's compatible with high-pressure EFI pumps and injectors, and the ethanol provides an evaporative cooling effect.
Disclaimer: I have consumed a few alcoholic beverages this evening.
Binford "More Power" Racing, 1989 Chevy Beretta GT
#1: "In my area, I have suddenly begun seeing more and more Berettas...what gives here?"
#2: "Simple: your neighborhood is getting overrun with meth dealers, and it's time to move."
I'll go ahead and give out another secret to our lemony water injection setup.
We hit the local WalMart before a race and pick up jugs of windshield washer fluid to spray.   Its already a mix of water and methanol - it just has a little bit of soap mixed in.  The soap seems to have no detrimental effect and we can really see a cooling effect from the water / methanol mix.
Dangerous Banned Technology (NOLA 09), Judges Choice (Houston 2010), Organizers Choice (NOLA 2010), Most Heroic Fix (Dallas 2010), $100 from Jay's Pocket (Dallas 2010), Dangerous Homemade Technology (NOLA 2010), Ununhexium Legends of Lemons Status,  Index of Effluency (Dallas 2011), Most Heroic Fix - (Houston 2011), Index of Effluency (TWS - 2012), Organizers Choice (Dallas 2013)
32 (edited by RobL 2012-05-11 07:10 AM)
Because all you just did was implement a second EFI set-up.
I'll try to keep it short by letting you guys do your own verification of some of my numbers ...
Stoichiometric for gasoline is 14.7:1 .
The best power is around 12:1
Most turbo application run up to 9:1
Why the differences?  Cooling.  Anything above stoichiometric is used to cool the intake charge.  So what I did was replace the cooling gasoline and replaced it with cooling water.  Water and not a mix of 50/50 alcohol because alcohol is a fuel and if I wanted more fuel, I add more fuel via the EFI.  I was running a fully programmable EMS that was also controlling the water injection solenoids based on RPM and boost.  The interesting part here is the 12:1 number.  It seems to be universal - in boost or in vacuum.  It's above stoich, so I imagine that it's that high because there isn't 100% homogenization and evaporation of the charge and you are not burning the charge completely.  The fact that engines soot and soot is a result of incomplete burning is proof in my mind of this theory.
So, what I did was calculate the latent heat of evaporation of gasoline of the extra fuel being injected (9:1 vs. 12:1).  I then figured out how much water I needed to replace that at certain boost levels and RPM.  You can basically ignore the temperature changes of your water injection as 95% of your cooling is via evaporation (people who throw ice in their water injection tanks amuse me).  So with water injection, you can run a more powerful air-fuel ratio safely.  There are also calculations that need to happen for air volume, post turbo temperature, pre- and post- intercooler temperatures and actual pressures throughout the intake tract.
OK, so we know how much to inject - The where to inject it was via experimentation.  I started post IC then went to pre-IC.  My thought process was that the water would have more time to evaporate and cool the charge.  I was right.  I believe that I had close to 100% evaporation by the time the charge got to the butterfly.  My temps were down.  A sidenote here is that you will reduce the "efficiency" of your intercooler.  They work by taking heat out of the system based on the differences in temperature of the intake and ambient air.  So if you reduce the intake charge temp before the IC, you are not going to get as large a temperature difference and therefore a lower efficiency.  However, your IC will not heatsoak as quickly.  Also, your turbo will spin different.  This is because you are reducing the pressure on the pressure side of the turbo via cooling the charge there before it hits the actual physical obstruction of the intercooler.  So instead of pressing against 20psi of air, you would be pressing against 17psi for example.  This is important since your turbo will spin faster to create the same pressure in the plenum.  So depending on where you are on your efficiency islands, this could be bad.
So why didn't that work better?
I did end up going back to the post IC and as close to the butterfly as I could.  The highlights are:  The intake charge temp ended up being a few degrees higher.  But I was able to inject more water before losing power/getting a stumble.  Overall I was able to get more power this way.  What I think was happening was that I was getting droplets of water into the cylinders.  This was creating a steam engine effect.  IE the droplets expanded to 1000x their size upon ignition of the charge and that created additional pressure and upping my "brake mean effective pressure."  So I had a higher pressure at a lower temperature in the cylinder - exactly what you are looking for in an engine.  Again, I can't prove anything but I think the droplets of water also helped homogenize the intake fuel charge whereas water injection pre-IC created a higher density air-charge that didn't disperse the fuel as well.
Anyway, that's my experience.
Why'd you need to run 9:1, crazy boost levels from a tiny turbo or something?  High compression?  I don't know anyone who even runs AFRs in the 10s, so I wouldn't say most run up to 9:1.  11s is fat enough for most.
11.8 to 12.5 generally covers the spectrum for my engine, YMMV.  Our lemons car at low boost is right in the sweet spot too...time to turn up the boost!
FastISH and the FURRiest 1991 Volvo 240 wagon
WV 13th, FL 8th (GRM), NJ 8th (B win), WV 4th (B win), NC 14th, NJ 14th, WV 62nd,  NH 17th, NY 54th
2012 Sears Point Outlaw...74th!
i think he meant all the way "up to" 9:1. i know a guy who runs an evo at 9.8:1 with 26lbs of boost. i think he is nuts, but it's his car.
35 (edited by RobL 2012-05-11 03:46 PM)
Yeah, I didn't really mean to type "most" - "some" would be more appropriate.  I know that my MR2 stock would run in the 9s and that there are some stock Porsche engines that run that rich too.  It's meant as an over-boost protection scheme.
