Re: Subframe Engineering - Y'all know more than I do.
The pre GM era Saab 900 (78-93) and first gen Chrysler J body (Stratus, Cirrus, and Breeze) were FWD cars with double wishbone front suspensions. Perhaps one of these could work?
I believe the adapter is for using a Ford Mustang strut front end in a Cobra replica. A friend was recommending using the adapters and a free pair of spindles he had instead of using Mustang II spindles on my Sunbeam.
https://farm9.staticflickr.com/8773/17235761194_87213dbbb3_o.jpg
BTW, I'm still looking for a Mustang II front suspension if anyone's willing to sell cheap.
*Raises hand, begins speaking meekly*
Hi.... everyone. I'm... Ted. And I'm an... I'm an attention whore. And I  will use any excuse to be on camera.
"everyone"
Hi Ted!
https://youtu.be/_bZwgOYTS3o
Idle Clatter Racing: 1979 Mercedes 300SD Delivery Spaceship,  "Not all ideas are good."
Fall 2013 CMP I.O.E.
Shine Country Classic 2014 and Southern Discomfort: Showed Up; Didn't Blowed Up
Humidi TT: DOMINATION. Barber 2015: "Least Southern Pickup Truck"
29 (edited by jrbe 2015-05-24 07:32 AM)
If you draw a line through the 2 ball joints on the spindle side you want them to be close to the center of the tire where it touches the road. Search kingpin inclination for more on this if it's new to you. The other thing is the steering rack may need to be shortened to help minimize/ eliminate bump steer. There are how to threads for miata racks and some others on how to do this. You may find one close enough to yours to reference if you don't want to switch racks.
I'm not seeing a bushing working up top because it will bind when steered. You probably need a ball joint there and need to make sure it doesn't bind as it goes through full suspension travel at all allowable steering angles so you don't blow that ball joint apart while driving. You can watch for axle plungeinto the cv joints and axle to chassis clearance issues at the same time.
I solved the hub carrier problem. It was a lot easier than I expected, actually. Turns out the OD on Austin ADO16 wheels bearings is the same as Metros. So I pressed the Metro bearing into the ADO16 hub carrier, and then mounted the Metro hub onto the ADO16 carrier.
http://i.imgur.com/ddXuSGdl.jpg
I've started making the subframe, and have the engine mounts done.
http://i.imgur.com/mEldjfPl.jpg
So now just to make some control arms...
