Topic: In-tank fuel pump wiring
So I'm swapping from a high pressure in-tank pump to a low pressure one, which is physically shorter. The wires built into the hanger now won't be long enough. Since the original wiring is riveted into the top of the hanger, I was planning on just soldering on an extension.
Do I have to track down some wire spec'd for fuel submersion? Do the splices need some special type of insulation prevent arc-ing? Is this all just a stupid idea?
Thanks all.
-Pat
351w Foxy T-Bird - Class B Winner!, 440 Bluesmobile - Judges Choice, Org Choice & IOE!, Camero, Fuego Turbo - Heroic Fix & IOE!
