Topic: Lap and sub belt mount check
I'm very new to prepping a car for racing. I was hoping for some input to the mounting points for my lap and sub belts. The car is an 88' BMW 535i.
Here are some pics of the mount points. The shiny bit is the drivers side rear floor. The rear seat mount (the thicker seat mount) is about an inch tall and I'm using a long eye bolt there. I'm assuming that it's okay to just tighten that down in place without anything other than the required 2.5 inch washer and grade 8 hardware even though the seat mount is hollow. Is that correct?
https://drive.google.com/file/d/0BzpbYv … sp=sharing
Here is a video of me pushing up on the floor pan near the left side eye bolt:
The concerns I have are:
1. The structural integrity of the rear floor for mounting the left side lap belt (check the video). I'm wondering if it's fine for the 45 degree angle that it will be pulled from in an accident. The actual floor has a rather large drain plug in the middle. A small 1/2" strip near the plug is rusted out.
2. Is it okay for the lat belts to come inward behind the seat? I can't mount to the door sills because that's where the brake lines run There are no jagged edges on the seat, so I am not worried about fraying for that reason.
3. Is it okay to have the sub belt eye bolt where it is? My only other choice is to drill into the frame rail which I was hoping to avoid.
Thank you very much for any input!
Fingers crossed that the links work O.o
-Dave
Edit: the links have now been fixed
