Re: Opel Prep for West Coast 2017
This makes more sense to me than whatever pseudoscience carburetors use.
1971 Opel Kadett Caravan for Lemons Rally
1998 Volvo V90 with Explorer 5.0 Swap for Fun
2003 Land Rover Discovery for Reliability?
heh...the neat thing about carbs is that the magic doesn't matter. Give them a supply of fuel, and they work.
I Survived Hell on Wheels
53 (edited by Red0ktober 2017-06-30 11:39 AM)
They never seem to work that way for me.
Carbs are the best!!! May need a sacrifice to make them work or pray daily, depends on which one you got.
1978 Opel/Buick Isuzu - 4 races, IOE, Incredible Feats in Badge Engineering 1996 Ford Probe GT - under a knife
http://i.imgur.com/m3KbADo.gif
Everyone has their favorite type of magic.
This was my temporary air cleaner when I got the MPFI setup installed, just the bits I had laying around leftover from other projects. It's actually 3" stuff squished to fit the 70mm/2.75" throttle body.
https://bby0za.by3301.livefilestore.com/y4m0qVy7RhNfELD2vE0Xt4hxZtZuhWuy6vV0bBIP1HpRhd_WNma2XJoEgSoYdoHqV0tHPID1LwL0QZw6Ijj1xOaTwfdVw_0yNN79W2ISfh8XDQ7ajCoIeDPv-qlJQBQnjfl8zwEAowgtSgElLf1ISk7gxzJFjRHpkytwyMOZEzSBh2DSs3gVq5vhp6-8sWsfyVnnspR-2Cb_9QeAnKUp-suKQ?width=1024&height=576&cropmode=none
Amazon delivered with a cheap air cleaner, some silicone bends and an aluminum tube. With a little trimming, I was able route the intake through an existing opening. Filter had to be installed from the front, but it fits great!
https://q0y0jq.by3301.livefilestore.com/y4m3Y7yj-N5msxFrsSTx_9pJtmVQEGZf56BDdK4IJyeytVzHnXECnPOMp7-UtxGCezPbYttwhm-liKcjQUjem5YQxjOcixcHrOGLKZ4TaaFXhbukml7WQvY8suYo9ZRJk215UV2ZdkJa3Mv4WIcmJ4P_CcxpOilyKJqYpWdykDLVCD3Mzh_4ekitpK4pFf0pvCx4Cl7pljgTb-lE7BlfNN00w?width=1024&height=576&cropmode=none
https://ruy0jq.by3301.livefilestore.com/y4mfHFIPAYgNBGtmjQUCOWvlngjKAajHFHPaethnD11AnccaBdU3t-XzOpa4alANyvUa2GB0xDk6QptqjlLUaxS-lVndCAwODRwVdWb4kykogFkENrHVzAiqCxyscJhtJSV0VkfwQtSPC30-w5qRAYKTY-IbTkFQSGwCJ9p-EKgsNqx_XWEQW2Wq7UF1mVBiUpf9qeLgLv-mEO_w_rndpZkHA?width=1024&height=576&cropmode=none
It's practically a Hellcat now.
https://qky0jq.by3301.livefilestore.com/y4mQCRS-Ad9YOqd9VUG5xxLNTqeKY7clBOSiP25D77kjO1OWo_oXNyY8rc8-dDHjlRRfgnw-HZxcym4UTv7cwzVs0gp7rUcO7RyODT-5ay61Whfxw7hDWOMlGR7JpOu5OcAfOqUUEWMpgxuaWsomLmUob0DHIEsn1toVlx8Mm8HLzZtHckLa9sUf7abdeD320kxnVhAoSeI8k1w-ywFQntG0g?width=1024&height=576&cropmode=none
I didn't think the original turn signal would fit, but thankfully the back of the housing sits right inside the center filter element. Super stealth!
https://qebpmq.by3301.livefilestore.com/y4mPksuLv0gyIvu4-xL_g-u5NEAt5PA4FL9iNnwb0QZKJ9Q7GJ8RApzGvWAg0yLwK9KL7ERmjMXgRnGij9gF-zNGgWxOAnJDHzqwENcY7blCp4FjX6nW-g-_AudoHYQuLYHEj_UaM_wXoz35tqXzqjKVOEnEjdbB1kQDgcQnTeDQR2H0eDnUAUtWQrJIYWkkIGrG2hEglm2NPA_B1wIQwaFFA?width=1024&height=576&cropmode=none
Front suspension is done. Poly bushings and new KYB gas shocks.
I don't think it's any more likely to kill me than it was before.
https://df15dq.by3301.livefilestore.com/y4mfayVL8P7YH_cvc6uPptXVEN-2NUysu4eI_KmY1N4SbOJxrdFy-328oUKQr5OEsI2otiaToUAo6bGA_E8y-bVCw68418znIl_OrbnJrGuah8WXvxaYtkLkqYyT_dP-kG9PPn7ZCZNtYup1cCxvOPN9jqVktfgLypOaHFhKlOQXoU-3XRuZL3TSc53B0h9qN88AMZXArzw7-s9hpXG7YGR2g?width=1024&height=576&cropmode=none
https://df0ugg.by3301.livefilestore.com/y4mAiLrHYvrozx7TSECiN39gatt_TI93g3P8ThkD77OTfS6nq4C3lGdPfYMX-hyvnzokJ5zWxWqBglSkzLe5wZXIoDa5i7MMd-kN3R6xpuhaTBvuznUtDLscgLn4mmLS9yD6WL5qrRN0Y4XBtQxwMc3q4qhx2xCUp42GBT0vcoDsH7z-eF6D0-8ky32cRHPVfIthGaXGrt64iXCMAFAy3BCuQ?width=1024&height=576&cropmode=none
Also, the battery is now securely bolted to the car. Allstar battery tray fits a sideways Optima. Had to go sideways to clear the cargo tray.
https://c115dq.by3301.livefilestore.com/y4my-ctv3sRmfIKFlzAS3fgr0fg3GcS9pT_8cio5ZVTKGyUCK0B3saEh7XYvfD6sBf5bG4kfa5elGPlzYPXmlDrkPmuCQP8GS8xOSOZga8o5kQxsoec1iC8JNIPzob03ostzNFTNyI5_0GvQTIOwEf5PI6w0eQ6XS2b6o52BeGHot6tn0fVD6lSQsqdN14v0yq6-0B2wMAWlvedXEjDt9s1EQ?width=1024&height=576&cropmode=none
I also just installed a stereo. My car was not equipped with one originally and had a blank panel covering the mounts. I tried to find a suitable shaft style deck, but decided just to zip-tie a universal housing under the dash. I got a digital media deck, so it's short and lightweight.
I used the original stereo location to zip-tie my USB and 12v plugs.
August is getting close.
https://ctkmgg.by3301.livefilestore.com/y4mRmCHpQTrR8QvJPYnAMc4d3cQM2yNsMaEpXL58uNVR9160l-qK0OvK-sOPf_Ctw5IGghOjrEv0JQ3zE0k1tknFtLtkMt7pl6lGOOWtPS6-o8JcAk13EImaouKeDEhs8S-nfbjXBTbZsClS1D1JUHqUuhrW8KiCPPOpAcE7zW3ZBR-p-lP0R3sUUBZX2ZoeHqJmpwgdkLrogxIEELOO1V0tA?width=1024&height=576&cropmode=none
59
There are plenty of questionable shaft style stereos on ebay. If you shop well, you can get one that accepts 8 track tapes.
This $32.99 Amazon Chinese seat beat can't be worse than the originals, right?
https://ddkmgg.by3301.livefilestore.com/y4m3CRpoz88Tcc_aJVSweeox-3w0v3NZDKrm7K-rcwod96yVVfZY4FV3gHCcBAOOR5CXKV-JaoBbVNkEPAW1pClUXdzhpd5plMLsAAIDM4h8b54vsjMxLlBb363EqUlY21lPj0fxAHE6w5ZfQ5bThUMHBW9QrGzcTrUvqdwlXuZvNE3MWkCOs0RjfB1MNyG9pcKCaMwIUDnwHOS8WYNspDCOQ?width=371&height=660&cropmode=none
The specs say this fan is only 2.11" thick, so it SHOULD fit. I'll have to pull the radiator to get it in place though. Also pictured is the external IAC block. Now the car starts and idles like a proper EFI car should.
https://dnkmgg.by3301.livefilestore.com/y4mU-k41keQnMd7Ayb9CoaZ5RRPDRdxB1BV1-AMlnpUEP5QijDaALzCTtRlaXrx2STakm4hK6j94nsAT_ZtOlnc_T8-TJezdlSFBWAJYypxENZJX3iwOwT-tnB-gN8XaTgBrNpwPo8H5UG2vG4Z0E746zhw2dPzxbJiY5kOnbdnw_6LOLOcfPT_fsCg3y5In59SKpETmnkf28e_cBdNeg5tSw?width=1024&height=576&cropmode=none
