Re: Still plugging away
JThw8 wrote:
dculberson wrote:
I think the "stubby" look is awesome.  It looks more like a car that 14 year old me would have drawn badly in the margins of my trapperkeeper.  Less overhang = cooler and more hotroddy.
Yeah, Im digging the look, reminds me of old SAABs for some reason.
+1
Can you do that to my A4? smile
How to you go from a 3" exhaust pipe to a 2 1/4 inch exhaust pipe....not simply it seems.  After playing with all the adapters at the local parts stores and coming up dry I just bought a 3" connector tube and decided to see what we could make.
So we focused the mathematical powers of Jim squared and figured the circumference of the 3" was approximately 12.5 inches and the circumference of the 2 1/4 was about 7 inches so we divided the difference by 4 then ignored all that and marked out some approximate pie cuts in the adapter.
http://d12473838.serv160.ixwebhosting.com/images/adapter1.jpg
Then we cut them out and bent everything inward.
http://d12473838.serv160.ixwebhosting.com/images/adapter2.jpg
An end cut of the 2 1/4 and a little welding and it was all done.
Now why did we do this?  Because we got a stainless steel Banks muffler for $20 and it had a 3" inlet.
http://d12473838.serv160.ixwebhosting.com/images/adapterdone.jpg
http://wartburg.misfittoysracing.com
OTTER: "I think that this situation absolutely requires a really futile and stupid gesture be done on somebody's part."
When I closed of the center tunnel you may have noticed I had left the back part open. Our cooling and fuel lines still had to be run and they passed through this section so I wanted to wait until they were finished to close it in. Also since our brake junctions and shift coupler are under here I wanted this panel to be removable not fixed like the front tunnel. For now its held in with some sheet metal screws but when the time for "prettying up" comes I will switch to dzus fasteners or at least rivnuts in the floor with button head screws. The final difference is this piece was made from a heavier gauge steel than the front tunnel. Since we eliminated the trunk the back seat area is the only place we have for luggage, tools, etc on the BABE rally so it needed to be able to support some weight.
http://d12473838.serv160.ixwebhosting.com/images/backpanel.jpg
Oh, and in case I didnt mention it, its now tagged and registered smile
Looking AWESOME, Jim! VERY impressive. You might be done in time after all!
Captain: Speedycop & The Gang Of Outlaws -'94 Mark VIII (Least Horrible Yank Tank Stafford '09, NOLA '10) '61 Caddy (Org Choice-NL '09) '63 Tbird (EPIC Repair Failure-Gingerman '10, I Got Screwed-Summit Pt '10, I.O.E. WINNER Stafford '10!) '77 Lancia Scorpion (I.O.E. WINNER Joliet 2010!) '67 Galaxie 500 (Judges Choice-CMP '11)
It's going to be down the wire.  The whole team is here all weekend.  We have to re run the fuel lines, wire up the whole car, finish brake install and bleed all the hydraulics.  Then its just a whole lot of reassembly, fitting of body panels and Im still trying to sort out a front sway bar.
Remember that part of my essay that said I couldn't promise the comedic value of marital discourse?  This weekend is my wedding anniversary.  sad    But it's the last chance we have.  It goes to Rob next weekend for the cage and the following weekend we leave for BABE.
So its do or die this weekend.  If it's not running and driving by Sunday night we're done.  But the lists are getting short and we're still plugging away at it.
It's Sunday night. Update?
Just came in from the shop.
Well....its alot closer.  It runs, kinda.  Engine is crap, hoping to find another but fixing this one.  It pretended to be a miata and chowed the woodruff key in the crank pulley.  So its not just miatas, its anyone who half asses a timing belt job.
I welded up the damaged pulleys and I need to see if I can find a woodruff key to fit back in or a piece of bar stock or something.
Brakes work, clutch works cooling system seems functional.  Exhaust is loud as hell,  not sure what to do about that, limited space means limited options.
Still to do, turn the bundle of wires in the cockpit into a harness.  Mount doors, tweak bodywork to fit over tires.  Adjust shifter. Mount seats. Install cage.  Electrical accessories and lights (kinda need them for BABE)  Probably a 100 other things.  Still not sure it will be done but we'll just keep pressing on.
http://www.youtube.com/watch?v=M317lrWTIRM
http://sphotos.ak.fbcdn.net/hphotos-ak-snc3/hs618.snc3/32507_10150213094670121_707995120_12740815_5442993_n.jpg
Sittin on temp wheels while the others are out getting new rubber on them.
Like I've said many times, you guys rock!  That will look awesome when finished.
BRE Datsun (Broke Racing Effluence) formerly Dawn of the Zed Racing
'74 260Z
Facebook page http://www.facebook.com/editpicture.php … 2559430584
This is a fantastic build and proves that with enough time and insanity you can build something truly epic from what would otherwise be considered a lost cause. Kudos to you guys, and I'm looking forward to seeing it at Capitol Offense.
Shallow Pockets Racing, aka the newbies in the BP-themed Golf
-Summit Point 2010, 29/86, 0 mechanical problems - "Are you sure it's a VW?"
docrice wrote:
This is a fantastic build and proves that with enough time and booze you can build something truly epic from what would otherwise be considered a lost cause. Kudos to you guys, and I'm looking forward to seeing it at Capitol Offense.
Fixed that for you.
Wow, you have done an amazing job on the old Wartburg.
Hope to someday race against you with the Dauphine ( which has a lot in common with your build )
1993 Linco Mark Ate
1957 Renault Dauphine
You drink heavily too?  smile
Capitol Offense will be its one and only Lemons showing Im afraid.  After that it gets torn down and made pretty for GRM.
We have a sad little MGB with no drivetrain sitting in the driveway waiting its turn at being the next monster out of Dr Frankensteins lab and it is being built with the intent of a long term Lemons career.  In other words, cheap. wink
You can actually build a Lemons car and not drink beer?  BLASPHEMY!!!!!
Pendejo - There is no such thing as a racing budget and if you can't afford to set it on fire and watch it burn while drinking a beer then don't race it.
I've heard rumor of such things but just cant fathom it myself.
I mean how do you convince yourself all your bad designs are a good idea when your sober?
Kinda looks like a 3/4 scale 51 Chevy sedan.
Kewl.
Hey, those phone dials don't look half bad. Maybe could be used as a "show" set.
I really like them actually. They are the "show" set for GRM but mostly because they only cost $100 with a usable set of Hoosiers for the autocross
Hey, give credit to young team captains such as myself (who won't be able to drink legally for another 7 years). I come up with plenty of crazy ideas, but I'm not always able to implement them...
Nick
Instigator of Naked Guy Racing, formerly The Knights Who Say Ni-ssan
I'm coming up short here - 21 to drink, -7 years = 14 years old.  16 years old to drive...  Unless you were in some legal trouble...
team captain doesn't have to be a driver? that's the only way i can see this working...
98 (edited by EriktheAwful 2010-05-27 04:44 PM)
It adds up if you realize he's too young to legally drink. That 7 key isn't far from the 5 if you're not sober. Just a guess though.
Well, all I know is that the Wartburg is coming here on Saturday for it's cage.  Sunday is going to be a time to work on the MR2 for Summit.  So I fiigure between those two events, I need at least a 1/4 keg.
100
Only a 1/4 keg?....I need copious amounts of alcohol at this point.
