Topic: cam lock or latch lock for harness?
Is a cam lock type harness a whole lot easier and faster to buckle than a latch and link type harness? Basically is it worth the extra 100 or so bucks?
The 24 Hours of LeMons Forums → LeMons Newcomers → cam lock or latch lock for harness?
Yes - cam lock is the way to go. You can insert the buckle end one at a time. With a latch type you need to get all 5 belts gathered up at once, in a particular order, THEN you can close the latch. If you miss or goof you have to start all over again. With cam lock you can do one at a time.
Spud
Last I checked you could a G-Force cam lock belt for $150 and Summit. But even if it cost more, it would be worth it. They are easy to use. Nuff said.
I have both, and use cam lock in my "real" race car, but for $100 savings (about the same number I found too), I think the latch style work just fine.. When I was a dumb kid, I had those in my street car too! Depends if you want to spend the money or not. I'm building up a new car, and will be using the latch style ones.
I am very proficent with the latch style, to me, its not worth the price for the cam.
Thanks for the comments. I just ordered a G-Force 5 point camlock harness from Summit Racing. If anybody is interested, I paid 128.00 for the harness from Summit. They priced matched Jegs price of 129.99. (I get orders faster from Summit)
Summit Racing link:
http://www.summitracing.com/parts/GFR-7 … mage=large
I caught a latch lock in my sleeve one time in the middle of a lap and knocked it loose. I've used cam locks ever since.
Imo, the best low-cost harness is this one;
http://www.summitracing.com/parts/RCI-9510CPL/ (available in 5 or 6 pt.)
seatbelts are only approved from two years (lemons doesn't necessarily care about this, but others might). After two years, you have to get a new one. With the RCI platinum series, you ship it back to RCI and they will re-web (or less-likely send you new belts) for free and put a new label on there that is good for two years. So basically, 4 years of approved harness use for one low price.
What kind of bushing do you guys use or recommend for the lap belt bracket to pivot? I saw this from Schroth.
http://www.schrothracing.com/store/Comp … n-hardware
Scroll to the bottom Sleeves for Bolt in Bracket
I like my M&R camlocks.
KT
With LeMons its four:
"3.5: Five- or Six-Point Harnesses: Five- or six-point harnesses mandatory, including fifth or fifth/sixth "anti-submarine" belt. All harnesses must be SFI or FIA approved; dated within four years of the race; and properly mounted."
yeah that is why I said "lemons doesn't necessarily care about this, but others might". Lemons lets you use a two-year belt for four, so after four years, I can send in my rci platinum belt, and get another four years for free.
We use the Simpson harness kit on the lap & sub belt.
Makes harness removal for vehicle work much easier:
+1 on cam locks!
We had to have someone else latch us in with the belts in the spring, we are now using cam locks.
