Save yourself a lot of effort and mess, roll it on with cheap foam trim rollers. Goes on much faster, no need to thin or mix, no need to purchase or setup a sprayer, 3x-4x faster than rattle cans, no messy over spray, much less prep of the garage/shop, not as temperature sensitive (needs to be above freezing), not humidity sensitive, no orange peeling, dries fast enough.
Our car took 3 coats to cover the original teal. We did one coat a day. Rolled on faster than I could have sprayed it.
You can see the excellent lemony results below. BTW, the flat rolled on the roof looks much better than the flat we previously sprayed on. The flat took one and a half coats.
2012 North Dallas Hooptie Judge's Choice Winners
If life gives you Lemons, install racing brakes!
https://www.facebook.com/JoBoRacing
