Topic: walbro fuel pump failure mode
So,
We had problems at MMC and we *think* our fuel pump is failing. The pump was a used Walbro 255l external purchased from a friend.
The symptoms were that after 30 minutes of good performance on Saturday morning, and then the engine would lean out under moderate load ( 40kpa, not even boosting). We tore apart our ignition system (hastily replaced Friday night after learning that COP’s can’t run in waste spark for more than 5 minutes on the same ignitors) over and over again, and then looked at the fuel system 6 hours later. Filling the cell with fuel (had 6 gallons left in the tank) seemed to work fine late in the afternoon for the last hour. We kicked ourselves and thought we were simply fuel starving, despite the other evidence.
On Sunday, the car seemed fine for 2.5 hours and then when I took my stint, it would lean out again under heavy load (greater than 100kpa- boosting). After checking the filter, fuel cell (ATL 22 gallon with the surge tank), nothing seemed amiss. Fuel pressure while idling was always 40psi, though we were using a tire pressure gauge on the schrader valve on the rails that would hold peak pressure. Instrumentation was definitely lacking.
We tried one more time late on Sunday, and now the car could barely move itself (and didn’t have enough power to enter the track, and I was able to get it turned around before needing a tow). Fuel pressure when running is still 40spi, but when we shut it down it fell to 25 psi. 10 seconds later it’s 10 psi, and then 10 seconds later it’s 0 PSI in the rails. No fuel leaks anywhere (All AN fittings in braided hose).
It MUST be the fuel pump (no stuck injectors), right?
I understand the Walbro to be a rotary cell type pump, with an integral check-valve to keep pressure in the rails. It seems the check valve has failed? In researching, It seems that these pumps are often sold with cushion sleeves (which of course, I don’t have- I’m hard mounted to the fuel cell cage with U-bolts). Are the cushions for passenger comfort, or fuel pump longevity?
What are the common failure modes of these sorts of pumps?
I’m interested in replacing the pump with something that is redundant. Are 2x or 3x Mercedes 190 pumps good enough to keep a 350+hp engine going?
And yes, we are adding a real time fuel pressure sensor to the digital dashboard.
Thanks
olaaf
