Re: Lemony Diff cooler?
I think the guys who built the twin turbo taxi used something like this. I bought one from them used but after deciding we didn't have a diff issue (never overheated one yet), I sold it off to Mike (Scrubby's owner).
http://www.ebay.com/itm/NEW-Electric-Tu … 1065464535Another tbird guy on the east coast showed me that he once rigged up a pump for his overheating diff cooler with a power steering pump mounted in the trunk. It was driven by a belt that went around the drive shaft. Very rube golbergy but apparently worked. Even if there was a little slippage, there was still some pumping of oil by the repurposed PS pump into the heat exchanger and then back into the diff.
-g
We bought the other turbo taxi return pump to make a diff cooler. 3/8 rubber lines, a big trans cooler done up very similar to the BMW, pump is draw-through, one difference... all was built level with the normal fluid to guarantee flow. Without it we would not survive.
If I were to do it on another car I would go up a size on all lines/fittings/cooler
Saying that, run some ducked air and a gauge to see if there is a concern before jumping through hoops.
Daytona 13th - Charlotte 9th - Sebring 2nd-Charlotte 25th broken brakes - Road Atlanta 14 10th-Daytona 14 58th- Humid TT 19th Judges' Choice!
