1 (edited by Dave 2017-09-14 03:11 PM)
Topic: Looking for soild info on medium case (188mm) bmw differential
Ive been looking for info on changing ring gears and this is what I found.  3.07 and numerically lower numbers are all interchangeable and 315 and numerically higher gears are all interchangeable.  From what I read, you can cross this threshold by adding or removing shims.(between the ring rear and the carrier)  What I am trying to do is go from a 346 down to a 279, does anyone know if this would require adding or removing said shims??
Thank you, Dave
It Ain't My Fault
Re: Looking for soild info on medium case (188mm) bmw differential
The ring gear stays the same diameter and the pinion changes size.  So going 346 to 279 means the pinion gets bigger.  This requires the ring gear to get thinner, or remove shims.  Don't know about BMW stuff, but a ring and pinion is usually a matched set.  Shims are used to set bearing preload and backlash.
The shims I am referring to is between the ring gear and case, I understand the process of setting up a differential, thanks anyway.
It Ain't My Fault
the shims on the medium case are to align the ring gear with the pinion.  Different ratios require different carriers.....Or sometimes shims are installed  between ring gear and the carrier it is bolted to....
Are you dead set on a 2.79? You can get a 2.93 with factory LSD.
