1 (edited by ninjacoco 2017-11-01 09:21 PM)
Topic: One Hella Busted VW 411 Needs Fixing + Engine Tins ASAP - Austin, TX
Hey! I'm trying to make the MSR Houston race with the Volkswagen 411 that won IOE at Buttonwillow and figured it's bad enough to list in the "on fire..." thread.
Here's the previous post on "oh crap, what am I doing with this car?" and all the work it needs: https://blackflag.jalopnik.com/everythi … 1819153463
It's pooping oil mostly out the passenger side of the rear, and Corey seems to think there's a rod knock? I've got valve cover gaskets on the way in case it's just that, but he said there might need bearings or a donor.
Does anyone near Austin/San Marcos know aircooled VWs super well? I'm definitely planning on spending my weekend trying to rip into this engine if I can. The car's at Harris Hill. I'm...kinda clueless. Holy crapballs, help?
Re: One Hella Busted VW 411 Needs Fixing + Engine Tins ASAP - Austin, TX
If it really is a rod knock, pulling the plug wires one at a time while idling is going to result in the noise getting a lot quieter when you remove ignition from the offending cylinder. Not that it matters which one it is, just pointing out a quick way to prove that is or isn't the cause of your misery. As for oil leak, valve cover gaskets are super-consumable on type 1 and type 4 motors ( type 3, too, come to think of it)
Swaps? Subaru engine with a manual, as suggested by Jalopnik, isn't lemony enough. This needs a Corvair six with Powerglide.
#111 Tradewinds Tribesmen VW Passat Inde ‘20... shhh, the Benz is napping!
#888-Hong Kong Cavaliers Benz S500: formerly known as OMG Racing #140...
Judges Choice and Regional Award winner! Chuckwalla '12, Buttonwillow '13, BFE GP '15, Miller '14 & '15, Sonoma '13,'14,'15,'17, '18. Inde '16,'17,'18,’19. Other foolishness: Finisher of Hell on Wheels (Jaguar) IOE (Humber)
NO SWAPS!!! Unless it's another Type 4 engine. Haha.
There may be a 1.8 type 4 hiding in my garage here in pa.
How to get it to you?
88 Festiva  -  Damn Tree!!!
"We Are Not Really From Iran" Festiva  -  Motor and Trans to be anounced
Well the Regular Car Reviews guy is always moaning about being bored on Twitter, and he's in PA.
Although he thinks 2 hours is a LONG drive.
6 (edited by ninjacoco 2017-10-14 09:43 AM)
Haha. Two hours is like, a good run for breakfast down here.
There's always the Lemons delivery system if someone's towing out towards this way. If it runs, I might be interested although TBH I'm a bit short on cash right now. (Because Volkswagen.)
I've got valve cover gaskets on the way right now. The old cork ones were pretty oily like they weren't quite holdin' it in. Holy crap, those are easy to get to on this thing. I like this car already, haha.
It sounds like a rebuild might be in my future, either way. What all do I need to find parts-wise to make that happen?
Good news, everybody! The guy who ran the Type 4-engined Type 3 we had doesn't think it's rod knock. It's rough and there's a butt-ton of blow-by, though, so it's gonna need a rebuild. Time to dig into the engine, I guess.
Dingle ball hone and new rings/bearings?
It's probably a really bad sign that I don't know what that is. Yikes.
We did a compression test. One side looked fine, but the sign that was leaking oil all over was not. 52 in the inboard cylinder, and 0 in the outer/rear cylinder on the right side. So, I tried to look at the head. I couldn't get it off in time and had to go home, at which point F1 week and a work trip took over, so I've gotten nothing done at all on the car.
I desperately need help from anybody who might know aircooled VWs if I have any hope of running this car at MSR-H at all. I'll probably pop down to Harris Hill later today to see if we can at least pry the head off to see if we can see any glaring issues there, and likely be out there all weekend trying to get it to run again.
Does anyone nearby have spare parts that might work on a Type 4/914 engine? Especially engine bits that might be borked?
It's a nickname for the Flex-Hone.
Fancy!
(Though I like saying "dingle ball" a bit more.)
Popped the head off on the offending side. Those two pistons and cylinders are tooooooooast. Rest looked OK; head is workable if I clean it up a bit, rods didn't have excessive play. I think the issue was that the rings on Cylinder 2 (the 0 compression one) were completely fused together and then started scraping the heck out of the inside of that one. Cylinder 1 (52 compression) was a little scrapey as well. More pics in the Race411 group: https://www.facebook.com/groups/1137556 … oup_header
I need two workable Type 4 cylinders ASAP. Where to find? Anyone have any take-offs that would work?
https://www.bugoholics.com/
https://www.yelp.com/biz/k-a-r-parts-houston
14 (edited by ninjacoco 2017-10-29 09:00 PM)
Oof, Houston's a bit far but could work in a pinch. Located up near Austin.
still hiding that 1.8 in my garage.
Does it run?
http://www.austinveedub.com/
https://www.facebook.com/VEEDUBAustin/
http://www.texasaircooled.com/catalog/home.php
https://www.aircoolers.org/
http://www.texasvwclassic.com/texas-club-coalition.php
Or just post for help here:
https://www.facebook.com/texasvwclassic/
18 (edited by fitsbain 2017-10-30 01:45 PM)
ninjacoco wrote:
Does it run?
Not currently, but that is because of the progressive carb ontop of it.
I believe it will run with proper carb.
But you should have all that already.
Add your intake and carb and away you go.
Its out of a 914 that was running before the rust got ahold of it.
I bought that car for parts and saved the engine. The 901 trans however met with a sawz all.
fitsbain wrote:
ninjacoco wrote:
Does it run?
I sure hope you are closer to her than Houston is.
20 (edited by fitsbain 2017-10-31 06:37 AM)
Spank wrote:
fitsbain wrote:
ninjacoco wrote:
Does it run?
Nope
Pittsburgh PA
Spank -
You met me at NCMP, I was Dave Morrows Cook.
If you get the parts from Houston, I happen to be off this Friday.  I could meet you halfway if you would like.
Skip "Mongo" L.
Team DadBod
Heckin' yes. I might could use help fetching parts.
So, it's basically down to finding those pistons and cylinders before the Rebuild Party Day (Sat./poss. Sun.—the only days I have), and here's the conundrum—what I'm pulling out are lighter (Brazilian cast) than the pistons I'm finding for sale (Chinese AAs and German casts).
So, I need to find either:
1. Two piston/cylinder/rings sets that sort of match the ones I pulled off. Stock 90mm x 66 mm 1700cc pistons and cylinders with concave/dish tops. Marked Brazil. Noticeably lighter than the AAs and German pistons I've found (in incomplete sets).
OR
2. A matching set of four stock 1700cc pistons/cylinders/rings that will work with my dumb engine. It sounds like the flat tops are interchangeable with my dome topped pistons, but let me know if that's wrong, dumb and a bad idea ASAP before I buy 'em. I'm getting conflicting answers on that and it's driving me nuts.
The big hitcheroo: MUST BE OVERNIGHTABLE TO TEXAS TO ARRIVE BEFORE SATURDAY, OR WITHIN DRIVING DISTANCE FOR US TO FETCH FROM AUSTIN OR HOUSTON ASAP.
That's really my only time to sneak a rebuild party in because a) weekend and b) I gotta work.
How much lighter? Could you drill the back of em to match or is it like really significantly heavier?
Don't obsess on what the internet tells you is right or wrong. You just need 2 pistons that match 2 bores. The closer you can get to compression the better, but it's not essential. Same for weight and even for bore diameter. I speak from experience.
Thanks to this forum, I learned that tungsten is a great material to fill wrist pins with to get pistons to match in weight when they are grossly disparate.https://forums.24hoursoflemons.com/viewtopic.php?id=6191
I also have run a motor for multiple races with 3 different bore sizes and compression ratio pistons (8.8, 9.4 and about 11:1 in the same 4cyl motor).
Just make it Vroom. Fix it right later.
Besides, it'll be a better story.
If someone from SoCal has a motor they want me to bring out to Stef to put in on Sat night at the track, I'll have a mostly empty trunk on the way out there.
I would have no problem help you get the parts.  As long as they are paid for, I could run them to you at no charge, preferably at a convenient meeting spot .  Maybe some sage advice because MSR will be our first race.....ever....(you all have been warned)
Skip "Mongo" L.
Team DadBod
