Topic: Rhodes weld in cage
Has anyone used the Rhodes roll cage? If so, what are your thoughts?
Thanks!
The 24 Hours of Lemons Forums → Lemons Tech → Rhodes weld in cage
Thanks!
We put one in our Mustang.
The tubes are bent, not all of them are notched.
It’s very labor intensive and time consuming. Took me 5x as longer to put in than I thought it would. Pretty sure that’s the case with any cage installation.
Bob
We used Roll Cage Components. Everything was bend and notched, just a little cutting to fit it in.
We used Roll Cage Components also...only some minor cutting required to fit...everything was bent and notched nicely.
Thanks for the info guys working on my first build so trying to get all the info I️ can
Pre-bent is a great way to go. I know in your other thread you said it was a miata, so the cages for those are all well defined. It will be very easy to fit up. I used roll cage components as well for my E36 and the kit fits amazingly well.
Most kits you order that way come with bars that are a little long and you'll have to do most of the notching and trimming. It's not hard, but you'll need to get used to how you measure and mark before notching. If you want to customize the cage give them a call, they should be willing to customize things like door bar styles, add in extra bars, etc.
The harbor freight tube notcher works, but isn't amazing. Mine has caged 3 cars and the bushings are finally shot. Clamp it in a vise and use a hand drill. You may have to shim the tube clamp to center everything. But for $50 it's hard to beat.
When you do assemble, tack the whole cage together, make sure you're happy with how it all goes together. It's hard to pull it apart and fix things later when you start finish welding from the start.
Since the miata is a short car pay extra attention to head clearance. The rules define that your helmet must be 2" inside the area of the cage (see the "how not to fail tech" doc for a picture. Make sure you set the main hoop high enough compared to your seat to not have problems at tech.
and if all this fail to meet the needs for height, add a bow bar in the mid-point of the halo and be done with it. There are SO many examples of this but more than happy to dig one up. If in doubt and ordering from Roll Cage Components, ask him to add one to the order...probably less than $25 if you do it at order time and you can install it or not based on your needs.
Thanks for all the great advice guys i am gonna order a roll cage components cage this week I’m pretty siked for the build and sorry no to come
