Topic: Drill bits
Looking for recommendation for a gift. What stays sharp forever, drills through diamond, and costs less than $1.35?
The 24 Hours of Lemons Forums → Lemons Tech → Drill bits
Don't buy them at Harbor Freight. Seriously, don't.
I disagree. They have an index of Cobalt bits. Lots of people have discussed them in machinists forums singing their praises.
And they guarantee them for life.
https://www.harborfreight.com/115-pc-co … 61886.html
Seriously. The cashier at Harbor Freight says they take back used drill bits all the time because they guarantee their tools for life. To me, that takes balls (bring back a smoked drill bit, that is).
I mean for the given price range the only other option is Uncooked Fusilli.
CowDriver wrote:Don't buy them at Harbor Freight. Seriously, don't.
From experience that is far too brittle unless it is steamed for at least a couple of minutes.
Now, three year old COOKED fusilli allowed to dry is much better. The aging process is the key.
Guildenstern wrote:CowDriver wrote:Don't buy them at Harbor Freight. Seriously, don't.
Any recommendations on cutting oil recipes?
If steel, you can find cutting oil at your local building supply store. Just go to the plumbing dept. and look for the area where they sell pipe threading dies, etc. Engine oil will do if you want almost as well. You want something thick so it doesn't get slung off by the drill bit as it spins.
WD40 works well on aluminum and if you have nothing else on steel as well.
I like to keep a small sharping stone around to dress up drill bits. Keeping the bit sharp goes a long way towards happy drilling!
Also I like to buy extra small drill bits, like 3/64ths or 1/8th inch in size. I use them to drill a pilot hole when I'm drilling a hole 3/8th or larger.
Ther're usually cheap and it saves the more expensive larger drill bits from dulling sooner.
OnkelUdo wrote:Guildenstern wrote:I mean for the given price range the only other option is Uncooked Fusilli.
Mostly used motor oil but in a pinch, you could use Canola or Peanut...just remember to leave the flavored olive oil on the shelf for this activity. Peanut oil smell like french fries a bit when it hits about 500f.
cheseroo wrote:OnkelUdo wrote:From experience that is far too brittle unless it is steamed for at least a couple of minutes.
I have some garlic sesame olive oil that I really like. Will it not lubricate well? I also like the smell of french fries. Is there a turning speed/bit size/material chart I can use that shows how best to get to 500f?
