Topic: Backstay angle question??
The way everything layed out with the car and the plates (which land on the frame) im at a 50 degree angle. I know the rules say to be right around 45. So what kind of leeway do they give on the angle???
The 24 Hours of Lemons Forums → Lemons Tech → Backstay angle question??
You will be fine with 50 degrees. They don't get out a protractor to check.
And knowing how janky, and/or iron curtain cold war surplus the protractor would probably be, 5 degrees is well within measuring error.
Thanks guys.
Just for argument's sake, FIA Article 253 regs state
They must form an angle of at least 30° with the vertical,
must run rearwards and be straight and as close as possible
to the interior side panels of the bodyshell.
I offer this because the moke was built really tall and I had to make sure I could still get the backstays at a safe angle. I'm at 34-35 degrees from vertical. I'm not saying it is ideal, but FIA claims it is within their "safe" range.
You're fine. Numerous 40/50 cars out there at Lemons events...hundreds.
