Topic: Corner scales
If you have a set to rent/lend and are in the Seattle area let me know. Thanks.
Re: Corner scales
Cripes are Lemons people corner weighing their cars now? We didn't even do an alignment this time.
Re: Corner scales
Alignment? What's that? Where you beat your suspension back into place with a hammer?
That guy
4 (edited by Guildenstern 2018-06-24 10:00 PM)
Re: Corner scales
What am I, a caveman?
A hammer and a String!!
Re: Corner scales
I had my car aligned before a race once. Then it dropped halfway off the trailer before said race. I haven't bothered even checking it since then...
Owner of the Knights Templar Neon
A&D of middling proportions
Re: Corner scales
I used to corner balance my cars before we moved to Class C. Now I no longer care. I still align them so the tires will last longer because tires cost money.
Re: Corner scales
We want to corner weight the 1947 Plymouth honestly for entertainment.  Will we use the data...sure.  Is that the real concern with a pre-war design, running modern everything else, not a chance.
Re: Corner scales
When we built our first car ('80 RX-7), it was scary as f*&$ to drive; the rear end was always trying to come around on you.  We knuckled under and bought a set of scales; turned out the LF corner was carrying a pretty high percentage of curb weight; the car was nowhere near what could be considered "balanced".  We ended up adding about 120+ lbs of weight to the passenger side where the seat would be, and the RR corner, to balance the car out.  It made a pretty substantial difference.
Over time, we trimmed more weight from other areas of the car (such as relocating the battery from LF corner to the right side behind the main hoop), which allowed us to remove some of the "reward weight".
Perennial Losers
Mazda 787b aka '75 914 - Org Choice @ The Ridge, 2015; IGS @ TH, 2018
