Topic: Pontiac Trans Sport and all other 3800 starter issues
So after nearly a dozen races with the Dustbuster we have it pretty well sorted with awesome brakes, a good manual tranny, OK suspension, etc, etc (did finally destroy the steering rack but that was a long time coming). One thing we have a NEVER fully conquered is the starter heat soak issue. Plain and simple the starter is under the front exhaust manifold and new, rebuilt or known good starters all suffer the same fate in warm weather races...it just won't crank after a spirited run. We have similar issues with the clutch line but those are rarer and we can always dump ice water on that, get the next guy out and just leave it in fourth.
Background: We drive this thing hard, out brake a lot of people, pull cars that did not think we could do it on the straights and don't suffer as badly as you would think in the corners (but it does suffer). Coolant runs a stead temp and oil runs on the hot end of the spectrum but not Chernobyl. Though there is room for heat shielding, I feel it would do no good because it is getting intense heat from both the engine and the exhaust manifold.
Looking for options but here are a few I have thought of:
Maybe a fresh air duct from one of the headlights directly to the starter
A remote controlled mister turned on when you enter the pit lane
Find someone that makes a truly bulletproof starter that can handle the heat of racing (GM starters of this era are not gear reduction)
A direct contactor of some sort that can used from the from of the car (air solenoid with copper plate)
I am open to real solutions as none of these seem viable. It push starts easily but some day it is going to be a problem.
