Topic: Need Buick V6 Help
I got a 1977 Buick Skylark with a 231 2-barrel on it. It has not run in a long time, like decades. I have to push the choke closed manually, but if I do that, then it starts right up. It idles fine, sounds really good, occasionally pops.
If I give it some throttle, even after it's warmed up, then it dies. I can see the streams from the accelerator pump shooting into it when I give it gas, so I think the carburetor is okay. I already bypassed the stock tank/filter and just put a small outboard gas tank on it, so it should be getting good gas. If I put it in gear, then it also dies. Sometimes if I goose it just right, then it will rev up, and then if I time my gear engagement just right, then it will peel out and I can drive it around the neighborhood at idle. This makes me inordinately happy. It will sit there and idle happily all day.
I was thinking it might be the distributor, but when I went to look it up, in 1977 some engines were odd fire and some were even fire. How can I tell which is correct for this engine without pulling the crankshaft?
Also, does it sound like I am generally on the right track with this? I'm happy to chuck parts at it; they are cheap. I can buy a whole new distributor and a new carburetor for half of what I'd pay for a Honda distributor. I guess I can just buy one of each distributor and see if either of them fixes it, but that seems gratuitous.
