Topic: UV-5R radio mount and wiring diagrams
As I'm rebuilding our car harness and want to remount the in car radio in something better than an old roll of duct tape zip tied to the center console, I figured I could share my knowledge a little bit.
First, I designed a 3d printed mount for the radio. It simply slides in and the spring clip holds it in place. It's very solid and I can't see it flying out, but add a zip tie if you feel you need to. There are holes and recesses for nuts on the back. There are two cable clamps, one on each side, to secure the wiring and antenna cable.
I'll be uploading the mount to thinkaverse, but until my account is cleared for posting the files are in my dropbox. If you happen to use fusion 360 I did upload the .f3d file so you can open the project and tweak to your heart's desire.
https://www.dropbox.com/sh/7gu49q8fin95 … g46Ya?dl=0
Thingiverse link here: https://www.thingiverse.com/thing:3150592
Next, the actual harness. this is iteration 3 of my in car harness. When I first built it I followed schematics I found online, but for whatever reason the signal from the mic was too high and the radio actually cut it off, and the signal to the speakers was also dangerously high. I first had potentiometers inline so I could dial in the right levels, and now i have replaced them with just resistors.
The radio has both a 2.5mm and 3.5mm stereo jack.
I designed this around the midland helmet kit. The connectors for the headset are fragile, so I ended up pulling the speakers and mic out completely and just making my own harness. I used the PPT button and connector because it's never unplugged so I'm not at a risk there, but you can use any button you want. The wire in the headset is typical pain in the ass headphone wire. Better to just un-solder the parts you need and make the new harness with better wire.
https://www.amazon.com/Midland-AVPH2-Cl … et+headset
Let me know if I can answer anything about the above, figured it wasn't doing much good stuck in my head.
Abandoned E36 Build
