Topic: 3" Driveshaft for T-56 transmission or other GM Trans - Houston, TX
Almost new 3" driveshaft with 27 spline yoke for T-56 or other GM transmission.  Turned out to be too short for our setup.  All you need to do is add your own flange at the differential end.  43.5" U-joint to U-joint.  1310 joint in rear and 1350 in front.  $100 plus packing and shipping or local pickup in Houston, TX.
