Topic: 2019 Seat
After looking at the rules, not sure what will pass tech. Does the Corbeau FX1 still do it, or do I need to be going down a new rabbit hole... Thanks!
1992 Merc-B 400E "Benz Green Machine"
total noobs....
The 24 Hours of Lemons Forums → Lemons Newcomers → 2019 Seat
What rule do you think you run afoul of?
I just want to make sure that I am buying the right thing. I'm in cray cray level of spend for "safety", so getting this right would be ideal!! thanks!!
That's the seat we use and when properly mounted (solid install with seat back brace if needed) passes without a second look.
Ok. Cool. I wanted to make sure that it wasn't in the ABS category. Summit racing for another two hundy. They should call this the 24 hours of Lemons + 2 hundy for every endurance race.
$300+ for that seat, right?
And the ABS seats are sh*t. You'd know them if you see them. They are like $50 and molded plastic.
https://www.summitracing.com/parts/jzp- … /overview/
https://corbeau.com/fx1-pro.html
first line of the description, it's fiberglass.
we too run that seat, never had any issues.
