Topic: Sunroof Rule Clarification??
3.J.6 No Open Sunroofs. All sunroof openings must be covered by either the original sunroof panel; a new panel securely fixed into place; or securely fixed mesh with openings no larger than 1/2-inch each. Glass T-tops or moonroof must be replaced with sturdy non-breakable material, or all drivers must wear arm restraints.
So everyone I talked to says sunroofs aren't required if you wear arm restraints but the way I'm intepreting this rule is that no matter what my sunroof must be covered and only T-Tops and Convertibles are exempt (which doesn't make sense).
So what's the story
