A couple points for the radio noobs. (note, I am not an expert, these are just things I've learned along the way)
If you're going to go with a programmable radio, you need to know a few things first.
1. The UV-5r radios, they are a grey area of legality. They can be programmed in a way that does make you 100% illegal using them. the can be programmed to be almost legal on the public areas, but they technically still dont' match all requirements. They will let you broadcast on frequencies that you should never broadcast on, like the NOAA weather stations. They require you do your homework before use.
2. Frequencies. There is a band of frequencies called FRS (https://en.wikipedia.org/wiki/Family_Radio_Service) that do not require a licence to use, but they have restrictions. You can't broadcast with more than 2watts, and the radios can't have removable antenna (where the UV-5R fails to meet the rules).
GMRS channels (https://en.wikipedia.org/wiki/General_M … io_Service) are shared with FRS for the most part, but you are allowed to broadcast with more power. You are supposed to get a license from the FCC, which is easy enough to get. A lot of people fail to get one because they flat out don't know, or are ok with the risk. You can buy a GMRS radio in a store and never be told to get a license after all.
There are also busness bands, commercial bands, MURS, and others that all require their own homework to determine how they are legal to use (if at all in our application)
The easiest path is to just stick to GMRS and make sure you're programmed to meet the rules of the frequencies.
An Important note on privacy codes, since a LOT of teams have no idea how they work. What they do not do is create your own private channel that doesn't interfere with anyone else. If you have a privacy code set, all it does is add a tone to the broadcast. Other radios, if set to the same code, will not pass the broadcast to the speaker unless it hears that tone. However you're still on that base channel, and anyone with no code set will still hear anything sent with the code turned on. As a result you get 5+ teams on the same channel, all with codes turned on, all trying to talk over each other because they don't realize they're still sharing a channel.
Mounting in the car.
There's a few ways to do it. They sell metal boxes with foam that radios go in. They're simple and effective, but you can't see the screen if that matters to you. Examples here https://pitstopusa.com/c-131995-cockpit … boxes.html
Or you can just find something to zip tie the radio to.
I made a bracket that the Uv-5r clips into that can be 3d printed, because I like over-complicated solutions. Links are in this thread https://forums.24hoursoflemons.com/view … ?id=37228l
Headsets
There's a few ways to do headsets. But the best is to make one or buy from someone like nerdie racing. We use motorcycle style speakers because then we can still use real ear plugs and don't have to worry about ear buds falling out. In the thread with the 3d printed mount I have my wiring diagram for making headsets.
Car harness
If you're mounting the radio in the car, you need to be able to connect and disconnect a driver to the system. Again the easy way is to make your own harness. The UV-5r radios use a combination of a 3.5mm and 2.5mm jack (I think it's the kenwood standard). you need a couple resistors and capacitors in the system too. Again, wiring diagram for the harness I've been using without issues for years is in that above link.
Keep asking questions. Radios can be complicated if they're not something you've dove into before, but it's straight forward once you do a little homework and ask.
20+ Time Loser
