The duck feet are terrible.
The cheaper alternative to the hydromat is the walbro pucks. Buy 4, build a tubing network to link them all together to the main feed port, and stick one in each corner of the fuel cell. Make sure you buy one with a bleed hole. They will close off when exposed to air to prevent you pulling air into the fuel system when you start getting low, and if you don't have one with a bleed hole you can cause the whole system to lock shut. If you use one bleed hole puck you prevent that. all kinds of info here. https://www.autoperformanceengineering. … ckups.html
we've been using them since we got a cell, a while before the hydromat was a thing, and they're awesome. We emtpy the cell to 1gallon or less left, and they give about a lap of warning before the engine refuses to run anymore.
never used a surge tank, plenty of others can weight in on one though.
20+ Time Loser
