Topic: OM617A piston questions
I have a very enthusiastic foster nephew? (I guess that's how he would be termed) with an OM617A that he has taken apart.  Apparently the ring lands are worn.  Top ring is .008 outside spec, 2nd ring is .004.  The question he is asking me about is ring groove repair shims which I had never heard of and thusly cannot provide advice.  Can you shim the rings in the turbo OM617 and if so, what caveats exist for doing so?  He says pistons are expensive for the thing and I really don't have any knowledge of that either.
Re: OM617A piston questions
Send a message to Rob(Type 44) here on the forum.....He is an MB guru.....And one helluva nice guy,to boot...
Yeah, I thought about him.  I have his email.
when I needed some rings to fit an obsolete piston, I went with Hastings. The nice lady on the phone helped me find individual rings close enough to what I needed and it was cheaper than buying sets
https://www.hastingspistonrings.com/ring-finder
I also used a ring groove "cleaner" loaner from Oreily's to cut the radial wall depth a little deeper to fit the rings that were available.
I've also seen (and repeated/reinstalled) where someone used the scraper ring from a 3-piece oil control ring as a spacer/shim for a traditional top ring essentially mimicking a gapless ring.
This was back when I was rebuilding A-series engines and actually staying within the $500 rules
Total Seal is in Phoenix, and will cut ring grooves to match off the shelf rings. They will also make custom rings, but the price difference is a wash.
I called them to find this out.
That guy
I like this idea better than shimming rings. It's a diesel... Compression is key. A low compression gas motor is a smoky, low power hot mess. Bad compression on a diesel is a stubborn no start. One of these scenarios is to be expected in Lemons, the other is a buzzkill.
Thanks for the kind words... I gotta admit, this kid sounds like he's dug further into a 617 than I've ever needed to, guru or not smile
