jimbbski wrote:King 1 wrote:Could you then theoretically attach the harness to the extension?
I don't think that would pass tech if you went with a "T" style as pictured. It might if you did it with two support tubes to the harness bar at both ends of the seat back support brace. But run it by the John P. first.
I agree; I wouldn't put the harness on it. I think I've seen harnesses mounted to a wide,shallow, forward-facing hoop, which is essentially what jimbbski is describing except with bends at each end instead of separate tubes, but I'd check with Pagel before proceeding. Either a hoop or the use of two support tubes would be a more elegant solution than our "T" anyway, even just as a back brace.
Edit: One other consideration is that if you anticipate enough range in size of drivers that you need an adjustable brace, I'd say just buy one as suggested by Brett85p, above. I don't imagine it's worth the time and money to make your own that would be good enough to satisfy tech, then still have to argue with tech that your homebrew solution is, in fact, good enough. In your particular case that still wouldn't address your harness question, though.
