Wow, thank you everyone for the advice and food for thought. Those of you following along at home, this is all in regards to the primary race vehicle, not the backup/daily driver.
So I've been window shopping Amazon for wire and supplies and I'm formulating something like a plan. I wanted to run this past the group for some feedback:
I think I can do this whole thing with 4 wire sizes (possibly 3):
1/0 or 1 AWG from battery to kill switch to starter relay to starter, and another (same size, different color?) from the starter ground terminal directly to the neg battery terminal.
4 awg from kill switch (switched side) to main electrical panel to feed multiple circuits (not sure on this one, seems like overkill. I went by the awg amp-distance chart and this is good to carry 90 amps 10 feet. Maybe 6 awg makes more sense)
10 awg for all individual components where I expect the amperage could exceed 15 amps. All of these would be on relays so these wires would run from the main hot terminal on the panel, through the relay, and to a component. basically just the radiator fan, wiper motor, cabin fan, and starter relay trigger.
14 awg for everything else: other relay trigger circuits, components not expected to exceed 15 amps (really I don't expect any of the components in this list to even exceed 5 amps, except maybe LED headlights IF i even have headlights)
The one place where I have a hard time believing my research is the ignition coil circuit. From what I've read, my conventional canister-type ignition coil and distributor "primary" circuit should only pull 4-6 amps? meaning I could wire the coil with 14 awg and a 10 amp fuse and it would be fine?
Opinions? I feel like all of these could probably go a size smaller and everything would work fine but I want everything beefy. I would probably use 30-amp fuses on all the 10awg circuits and 5 or 10 amp fuses on all the 14 awg circuits depending on the component. possibly a fusible link in the 4awg feed line?
