Topic: Subaru powered rx7
So ah, I've been watching videos for quite a while on these races and builds and whatnot, but I was wondering what you guys would think of a 1983 Mazda rx7 with a 1995 or 1998 ej22 Subaru engine paired with either the RWD 2013 brz transmission I've got lying around or a stock manual and trans. I had(have, but just sold it) a 1980 rx7 I slapped a 1995 ej22 with a 2013 brz trans in and it worked alright, just kept overheating. I was thinking I would like to go the AWD route because AWD domination and all, but the main problem I have with that whole setup is that it would push the engine another 6 inches forward so the engine would be just 2/3 in front of the centerline of the front wheels instead of right in the middle like it was with the brz trans- and then I have no place to mount a radiator. So pretty much where should I mount a radiator?? and what class does that sort of thing run? c? b? tis pretty jank and I don't feel like changing the headgaskets since the 1998 engine I just picked up only had 128k supposedly. I know nothing means anything till its actually built but any insight would be appreciated.
