Topic: Racing Truck without a Bed?
If I completely removed the bed on my s10 but put trailer fenders around the wheels, would it pass tech?  It would not be OE fenders but they are fenders that surround the front, top, and aft part of the wheel like the stock wheel well.  I wanted to do some crazy aerodynamic stuff where the bed was instead.  Thanks!
Re: Racing Truck without a Bed?
Guessing you want to do something like this.  So yes, been done.
http://www.roadkill.com/wp-content/uploads/2016/03/Roadkill_Apex_Toyotar0009.jpg
That should be a "Yes, but..."
Check with Pagel. Since that truck has run (in that configuration) the rules have been reworded and OEM crash structure requirements added. There have been calls for some sort of rear-mounted energy-absorbing on other pickup trucks since then.
So Yes, you can run with trailer fenders, but... check with Pagel to see what else you may need back there to prevent a car from running up the rails and into your cab.
I don't see why not. We have raced a few PU's w/o beds in Lemons. Most use trailer type fenders.
I asked Pagel and he said, "The bed is part of the crush structure, keep it."
However in the rules it states:
3.D.2 OE Crush Structures. Modifications that reduce the size and/or effectiveness of OE crush structures — including but not limited to shortening or removing frame rails or unibody structures outside the wheelbase — are discouraged in the strongest possible terms. Cars with compromised OE crush structures are exceedingly likely to fail tech.
A truck is not a unibody structure and I was not going to change the frame.  I think it could pass tech, especially if I added a full rear end collision prevention system.  Thoughts?
6 (edited by piper.gras 2020-08-05 10:54 AM)
Disregard advice from Pagel at your own peril. Doing so will put you in a position where you are extremely likely to fail tech. At the end of the day he's the one who gets to say whether or not you're allowed on track with whatever you build. If he tells you not to do something, then you do it anyway, and he's there tech'ing your truck, it's probably not going to go your way.
You are not going to have a problem. As mentioned there have been several PU w/ the bed removed to suit their "theme"
The wording in the rules have changed since those bed less race trucks have participated.
Pagel is the guy to pass/fail your safety inspection.
Trying to find a loophole, when you have the answer from the man himself is foolish.
Also, your nit picking was based on old trucks that ran before the rules changed.
Taking out the exact thing the new rules say not to take out is probably a good way to go from race car owner to spectator.
Former Captain
1996 Crown Vic. #55
Team Racing Cosmo
I want to believe you aren't suggesting to explain the rules to Pagel.......
It is not in your best interests to attempt to go around him on a direct answer to your question!
As a part time judge, I can tell you Pagel is the last word on anything safety. (He has parked me and I work with him sometimes)
A word of caution......
Manny
The answer lies within two other parts of 3.D.2:
3.D.2 OE Crush Structures. Modifications that reduce the size and/or effectiveness of OE crush structures — including but not limited to shortening or removing frame rails or unibody structures outside the wheelbase — are discouraged in the strongest possible terms. Cars with compromised OE crush structures are exceedingly likely to fail tech. Non-OE replacement crush structures are not an acceptable substitute; you and your stick welder ain’t NHTSA.
If Pagel's interpretation of the current rule is that the bed is part of the crush structure, then the bed is part of the crush structure.
11 (edited by bobnowoc 2020-08-05 03:15 PM)
And the lord layeth down the 11th commandment from on high to his servant, Saint Pagel and He sayth "The bed is part of the crush structure, keep it."
Spank 3:16
Former Captain
1996 Crown Vic. #55
Team Racing Cosmo
12 (edited by Mr.Yuck 2020-08-05 03:32 PM)
I find the entire "crush structure"  thing silly. yes I get that you shouldn't mess with the factory frame or uni-body. But a lot of the cars have gutted hoods, doors, trunks..the roofs are nothing but sheet metal. So why would it matter if a full frame PU takes the bed off?
Really?
You cant see a reason crappy 25 year old, unwanted $500 vehicles pushed to their break down point for 8+hours built by a couple of rednecks with no automotive experience and driven by 20 year old college students on a hair pin track might need crush structures?
I can think of a few
Former Captain
1996 Crown Vic. #55
Team Racing Cosmo
14 (edited by bobnowoc 2020-08-05 05:22 PM)
https://youtu.be/EDVwSNDfsqU
https://youtu.be/4rRqRKC0nG8
https://youtu.be/838hOUNdycc
And dont forget https://youtu.be/49bU5HCNobo
Hey.  The truth is you can build anything you want.  .....
And Pagel can fail anything he wants
Former Captain
1996 Crown Vic. #55
Team Racing Cosmo
bobnowoc wrote:
Really?
the bed of a pick up truck isn't going to stop some sort of catastrophic event. You have a huge ash cage for that.
16 (edited by bobnowoc 2020-08-05 06:48 PM)
Crush zones are for all the vehicles in an impact. Not just the pickup truck in question.  And not just catastrophic hits.  They help in fender benders too.
Wait a second.... are you intentionally trying to get a rise out of me?
I just realized...
You played me.
I know You cant really be this clueless.
Playing the fool, in order to make me look foolish.
Well done Yuck.
Pretty funny.
You got me.
See you on the track.
Bob
The answer is always the same.
Wanna do a crazy build? Ask Pagel then do it his way
Former Captain
1996 Crown Vic. #55
Team Racing Cosmo
I think THIS is the most relevant video to post with regards to Should a truck have a bed on it or not...
https://www.youtube.com/watch?v=LX0kZGQJmnA
Thank you everyone for your responses.  I think I'll end up keeping the bed.  I really wanted to get rid of it to lose weight and make some money back on the purchase price. However, I really don't want to fail tech.  I brought up the rule definition only to get community feedback on the likeliness to pass tech because Pagel is god.  I thought I might have some leeway from prescient.
If they fail your bedless truck then all the others need to go find a bed before they race again. I guess you could gut the entire floor out to save some weight.
If no-bed fails, removing the bed floor is a fail too.
Removing weight from the back of an already highly front biased vehicle probably isn't going to do you any handling favors anyway. Keep the bed, and the traction that comes with it.
I had plate steel that I was going to bolt and weld to the chassis just so it wouldn't go anywhere.  I really wanted to get rid of the bed for money first and foremost but to improve aerodynamics secondly.  I paid more than $500 for the truck and thought I could get money back because the bed is brand new.
You could do what I did with the Prius when I stripped it and sold off the good parts: Require that the buyer of the good panels give you their old beat-up parts as a "core" and sell them the nice one at a discount. Some $ is better than no $, and you'll still have a bed to bolt on!
There are plenty of cars that have been around a long time where the rules have changed yet they have been granted grandfathered exemptions for one thing or another.  At the point where they don't want to see it anymore or want changes before it's next race, they'll let you know.
If the bed is in that good of shape then try to source a used one that's off the same model vehicle. It can be rusty and/or dented and that should make it cheaper!  Then sell your "Good" one and deduct the difference from the amount you spent.
The rules allow you to do this. It's the same as if you replaced a door or hood. It's legal.
