OnkelUdo wrote:So find out where they make power and then were they are just making more noise...that crossover point is your rev limitter.
It took us 3 years, but once we finally ran our '99 Camry V6 powered MR2 on the dyno, and made some fancy graphs in Excel, we realized that we should be shifting at 5300 RPM instead of 6300 (fuel cut), so now we only go past 5300 on long straight aways in 5th gear. Lots quieter, saves some fuel, win-win. Should have done it 3 years sooner.
I think we got ~25 races on our first junkyard engine. It's still in the car, it finished the June Gingerman race, and while it passes the Autozone "block tester" test, I think it has a leaking head gasket. We shall see. We do run 10 quarts of oil which might be the reason it hasn't chucked a rod.
