Topic: First Time Racer starting build!
Found Lemons via someone talking about a BMW race body swap on a Datsun page. Decided to dive down the wormhole with a few of my buddies and take the plung.
So we decided on a s10 for a first vehicle, 4.3 v6, easy to work on, ect. Plus I haven’t seen many trucks on the page or in pictures, gotta be different!
First truck we found and bought was a 2000 S-10 Extreme ext cab. Should have known this was gonna be a loss leader when I saw the bullet holes in the tailgate! It ran, but had transmission issues that seemed like an easy fix, so we brought it home. Our original plan was to mid engine mount the v6 in/behind the cab and bed, and link it up to a 94 RX7 rear end I found locally.
The truck ended up being a rust bucket, so we are just going to pull the engine, some plastic, and scrap the truck.
Found a second truck for cheaper ($150) with a V6 and manual. It is a 1995 reg cab, long bed, so will be a little lighter. It will need the cab corners fixed and the drivers floor board. We scrapped the mid engine idea and are gonna install the rear end from the RX7 in this for IRS. Pic up that truck Thursday.
Living in Northern Ohio we plan on running Gingerman, Pittsburg, and maybe the Chump Series at Nelson Ledges because its so close to home.
Here are the plan for the truck and how we are gonna budget it out. If we go over, it wont be more than 100-200 dollars
Truck – 150
Rear end – 250
Floor board – 30
Cab corners –30
Lowering springs – 30
Misc Sheet metal – 100
Im sure we will have more add up, but that’s the start!
So with reading the rules any of these components are exempt from the 500 correct?
Brakes, Wheels, Tires, Fuel Cell, Cage correct?
Looking at cage options, I have a friend that can weld up the cage no problem. Getting a good bender is the issue, so we are thinking of going the SC Racing Parts cage route. Pre bent, then we will Mig/Tig weld it up. Does a cage have to be Tig’d? or Mig’d?
Looking forward to going racing next year!
