Got the seat mounted in the car today and I'm starting to think about how I'll put in the cage
For the main hoop, there is a ledge where the rear seat sat, it's pretty far behind the B pillar, but is just about 6 inches from the seat (we'll need a brace). It's very strong, rust free, and flat. Would be easy to weld in spreader plates. The other advantage is that it's elevated, so it should allow me to drop the main hoop to the floor, weld in the halo easily, then lift it back up.
The tempo has a very protruding dash, but I think we can just cut out a section of it (marked by the yellow lines). The only thing there is the headlight control and a vent, which we can move/delete.
From there I think we can run the down bars to the floor pretty easily, the floor there is pretty flat and strong. A dash bar might not be possible without something pretty bent / custom, but as I understand they aren't required.
For the backstays, there are a couple good places. The suspension towers or the trunk floor are both close to 45 degrees back and should be doable.
Planning on ordering a cage from roll cage components in the next few weeks. I went through the instructions and it seemed pretty straight forward. One thing I wasn't sure about was if they include some spacing from the roof or if I need to subtract a half inch to give us some buffer. I'll be sure to ask when I order.
I'd love you all to throw FUD on this plan if you can think of any.
