Topic: Bad Vibrations
Our car (1996 Mitsubishi Mirage with a 4G64 motor swap - 2.4l 4 cylinder) seems to be plagued by vibration issues. In the last race at MSR- we lost multiple electrical connections, the fornt heat shield over the manifold cracked. the bracket that supports the intake manifold also broke into two pieces. The alternator came apart. The oil filter mount cracked in two. And apparently the engine separated itself fom the transaxle. I know that 4 cylinder engines suffer from inherent balance issues, but this seems a bit extreme. I was wondering if anyone else had experienced this sort of thing. Or is it just my particular engine may have an issue?
Any thoughts out there?
Thanks, Monty
