danielp3344 wrote:I hear you guys but TBH I'm looking forward to picking out a car and making it race ready more than anything else. Also, I'm getting a nagging feeling I'm missing something about this roll cage thing. Are most people here just not big on welding? It seems like if you have a welder/angle grinder/tubing bender you should only have to pay for materials themselves right?
For most people it's the fact that if you are not 100% confident in your ability it is not worth the risk that you do it wrong and hurt a team mate should you find yourself in a crash that requires the cage to work. That's the blunt answer.
If you've never built a cage before, it's more complicated than you think, but it is completely doable. I've built 2 now. One all from scratch, one from a kit. Getting the cage to fit nice and tight to the car so that you have the required head room takes a lot of time and planning. Building door bars that both protect you as much as possible but allow fast egress in an emergency takes time and planning. You also need to be confident enough in your welding to do it laying upside down with 1 arm in a stupid position while barely being able to see. And never, ever, take an angle grinder to a weld or tube on the cage. Ground welds are a fail. Ground tubes are a fail. Read all the rules many more times.
I also enjoy the car prep almost more than the racing. It just took a long time for me to research everything I needed to on how to build a cage, and practice my welding enough to be confident that I could build a cage that would protect my family should it ever get tested. (my team is my dad, my siblings, and me). I was ambidextrous with a MIG welder before I even thought about trying a cage. Crashes in Lemons bad enough to test your cage do happen. https://www.youtube.com/watch?v=4rRqRKC0nG8
As for doing this as cheap as possible, I applaud the idea, but please do not skimp on safety. Buy a cheap car, use on hand parts, do dumb things with motors, use cheap tires, build anything yourself that you can, whatever. But do not skimp on safety. Brakes are often overlooked by new teams. BUY GOOD BRAKES. That video I liked of the crash at thompson? They were using cheap street fluid and boiled it. Having also boiled brakes, it's terrifying and rarely gives you warning. Put real race fluid in your car, buy a moisture tester (they are like $20 on amazon), and test your fluid before each race. Buy good pads. ST43s are the magic pad for this, but they will cost a bunch. They are worth it though. Buy a good set of belts. Cheap belts are almost impossible to get tight enough which puts you at risk. Crow makes a nice set that doesn't hit Scroth levels of money. Buy good gear too. Personally fire scares me more than anything else in racing. I'm happy to have bought a nicer suit to replace my cheap intro one that was just heavy cotton instead of nomex. Basically I'm trying to say don't let your pursuit of doing this as cheap as possible end up making you compromise on the safety of you or your team mates. Lemons is cheap racing, but it sure isn't cheap.
20+ Time Loser
