Topic: How to trick our turbo into blowing harder
We got motivated to better understand why so many folks are blowing by us on the straights, so we got a dyno run on our crappy Lemons car. It was a great experience lining up behind the highly tuned C8 vette for our turn with our screeching brakes. I'm pretty sure they would get out of our way on the track.
We have a 2005 GM Ecotech B207R (LK9), with a Mitsubishi TD04L-14T stock turbo.
Our air/fuel ratio is at about 13.1 up to 3500 RPM (with boost about 15), then dips to be rich (maybe 12, with boost of 12) then after 4500 dips again (maybe 11, boost of just above 10).
Clearly a bigger turbo would help push more air at higher RPM, though have the lag issues at the lower end. So not clear that is a win overall.
From some chat around the garage, it seems folks typically get much better than this - i.e. more boost after 3500, and higher max boost, perhaps closer to 17.
It was suggested the boost control valve may be worn / old and try replacing that. Is this a thing?
I also found a video https://youtu.be/csa9A5lZZok with a smoke machine to find some leaks with o-rings, gaskets, etc. No clue where we could borrow / rent / buy one of those some machines though.
Anyone else running one of these engines turbos and open to sharing what they are seeing, and how they tuned it up?
Thoughts on what we should / could look at for testing / investigating more is greatly appreciated.
