My fav Heroic Fix involved an 82 Supra. Race was Lemons first true 24. Supra gets a rod knock about 30 minutes in. The Reno-Fernley track is in BFE so no local parts stores have rod bearings. They find a Cressida in a DIY junkyard a couple hours away. Place has no hoist so they cut a hole in the oil pan of this 200k mile Cressida and remove rod bearings one at a time thru the hole. Put them in the race car and rejoin the race after midnight. Immediately throws a rod out the side of the block. They get all the pieces out of the pan, wrap a beer can around the crank where the rod was, use expanding insulation foam to fill up the block holes and disable the injector on that cylinder. They go out with 10 minutes to go in hopes of taking the checkered flag but engine locks up solid half lap in.
You maybe want to look at those bearings.
1990 RX7 "Mazdarita" 1964 Sunbeam Imp (IOE 2013 Sears Pointless) 2002 Jaguar x-type (Winner C-Class 2021 Sears Pointless)
1994 Jaguar XJ12 (Winner C-Class 2013 Sears Pointless) 1980 Rover SD1 (I Got Screwed 2014 Return of Lemonites)
