Topic: 1992 Caprice - Breaux Bridge LA - $500
1992 Caprice Wagon, battery is dead and transmission isn't working, can be flat towed. Title in hand. Engine was running when parked, power steering, brakes, and speedometer worked when flat towing. Interior and exterior are ok, driver power seat works. Originally a 5.0 engine, previous owner replaced with 5.7 TBI. Factory limited slip differential with 3.23 gears. JA2 brake code and V08 cooling code.
Was planning to make it an 8 seater tow/cruising rig with option to swap engine for LS / carb (manual valve body to eliminate TV cable), but never had time to work on it. Now I'm moving 2,500 miles away and I don't feel like towing it. Parts available but not installed: Elgin E1128P camshaft, TCI 376015 manual valve body, ACdelco 45H3081 rear lowering springs~3" drop, electric cooling fan with thermostat. Located in Breaux Bridge LA.
Re: 1992 Caprice - Breaux Bridge LA - $500
Hi. I'm very interested in purchasing the TCI manual valve body P/N 376015.
Karl Staggemeier
Karl@CASupercharging.com
714-861-9656
