No offense, with your concerns...might just want to have Jim from Roll Cage Components install it for you. Depending on where you are in the DC area, he could be as close as 2 hours away.
Now, back to the questions:
Jim's measurement guide is pretty comprehensive but for a fee he will go to the junk yard and make the measurements for you if he does not already have the car on file...call and ask. On that note, since it is 2-door, pay the extra for the nascar bars.
Almost all tubes will require some trimming so even if your measurements are a bit off MOST of them can be account for there...especially with a convertible.
Making the cage taller, convertible or not, is rarely a bad idea unless you need to store the car outside needing it to be weather-tight. Most of our cars have had a bar between the halo and main hoop near the center for extra clearance.
Now for the the things you did not ask:
There are realistically only two places to get a prebent kit that will not either fail tech or require significant rework to not fail tech...one is 2-3 hours from you in Roll Cage Components.
August is doable if you start now as new team but do consider seeking out one of the MANY teams in your area to find a mentor team. You need to start with seat placement in a stripped interior first to make sure you can find a seating placement that works for all drivers...you can order a cag without this but once you start tacking one together you are going to be increasingly resistant to changing things.
As mentioned above, if you install yourself you will be trimming tubes, potentially notching two or so, fitting it, tacking it in place, welding spreaders to dodgy sheetmetal on all sides with no gaps then welding all tube to plate and tube to tube joints 360 degrees. All of that takes time, some of it a moderate amount of welding skill and some more of a talent at making imperfect welding look good (spreader to sheetmetal is not fun). Blanace that against allllll the other things you have to do verses just dropping it off at RCC.
I am missing a lot here on purpose but there are a ton of threads in the nebies section on what you need to do to get to your first race.
